AE86 weights list
03-26-2013, 12:24 AM
AE86 weights list
I think an empty hachi will never go below 800 kg. even with all plastic windows and other body panels. But ok, Lets see where this will take us.
Maybe XTR can wheigh their car for us ?
03-26-2013, 08:53 AM
AE86 weights list
Im assuming the doors have no mechanism or door cards etc. I replaced my door with a fibreglass one and the total savings was less than 10kg (kept the glass and card and manual winder.
03-26-2013, 10:25 AM
AE86 weights list
FRP doors are bare, no mechanisms or glass
OEM door is also without glass, but with mechanism
Good to ask these things, they make a big difference.
More to come, but exporting is a bitch Smile Anyone willing to measure stuff themselves: THANK YOU.
I'm very interested in stuff like lights, wiring loom, HVAC unit, dash skin etc
03-26-2013, 01:49 PM
AE86 weights list
i will see what i can do tonight.
got my scale noteboke with me for when i go to the shop Smile
03-26-2013, 05:01 PM
AE86 weights list
robokill Wrote:I think an empty hachi will never go below 800 kg. even with all plastic windows and other body panels. But ok, Lets see where this will take us.
They'll weight mine before they take the blacktop out, and then after they put the SR20DET in Smile
AE86 GT - SR20DET BlackTop //// Trackday beater
Citroen C4 Coupe VTR - 1.6HDi //// Streetcar
03-26-2013, 06:30 PM
AE86 weights list
That would be good data.
Like the CA18DET, the SR20DET is a 60kg penalty even before you start adding the oil cooler, intercooler and blow off valve necessary to run it on track. Seeing as you now have those parts sitting in your living room ;-)
As a data point: my street legal Trueno, with CA18DET, fully stripped, racing seats, no cage: weighed in at 1040kg.
03-26-2013, 06:50 PM
AE86 weights list
This Thread is great,
got some Specs for your list Wave
Flywheels, Source Google:
Stock: 8.6kg
Exedy: 8.9kg/ also available with 4.9kg (dunno why one of them is heavier than the oem Huh )
XTR: 4.5kg
XTD: 4.1kg
F1 Racing: 4.5kg
Fidanza: 3.7kg
Toda: 3.7kg
TRD: 5.5kg
Engine, Gearbox, source Google:
Nissan CA18DET: 128kg
Nissan SR20DET: 139kg
Nissan SR20DET Gearbox: 44kg
Nissan RB25DET+Gearbox: 302.5kg
Nissan VH45: 230.4kg
Toyota 2JZ-GTE: 269.4kg
03-26-2013, 07:39 PM
AE86 weights list
NoHachi Wrote:As a data point: my street legal Trueno, with CA18DET, fully stripped, racing seats, no cage: weighed in at 1040kg.
Why I chose an E7... most models come in around/under 1000 kg Huh For example... my E7 sport coupe body, as a 1600GT (2TG power), is listed as 975kg
Dan -
03-26-2013, 07:54 PM
AE86 weights list
Well, if you removed the handicap called CA18DET it would have sat at roughly 975kg for a stripped 4AGE hachi with all fluids. So pretty similar.. it would have been quite a lot slower too though.
I'm not seeing big sources of weight differences between the E7 and E8 models. Same chassis, similar panels, engine = same, glass is very similar. Rear axle = same. I think they are a similar starting point, give or take a percent or two.
03-26-2013, 08:06 PM
AE86 weights list
NoHachi Wrote:Well, if you removed the handicap called CA18DET it would have sat at roughly 975kg for a stripped 4AGE hachi with all fluids. So pretty similar.. it would have been quite a lot slower too though.
chassis dimensions the same(similar)..... but the chassis is NOT the same... a number of supports the AE86 has that was not in the E7 line. Doors are not the same(no upper frame on long door E7)
Dan -
