AE86 weights list
03-26-2013, 12:24 AM
AE86 weights list
I think an empty hachi will never go below 800 kg. even with all plastic windows and other body panels. But ok, Lets see where this will take us.
Maybe XTR can wheigh their car for us ? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
03-26-2013, 08:53 AM
AE86 weights list
Im assuming the doors have no mechanism or door cards etc. I replaced my door with a fibreglass one and the total savings was less than 10kg (kept the glass and card and manual winder.
03-26-2013, 10:25 AM
AE86 weights list
FRP doors are bare, no mechanisms or glass
OEM door is also without glass, but with mechanism Good to ask these things, they make a big difference. More to come, but exporting is a bitch Anyone willing to measure stuff themselves: THANK YOU. I'm very interested in stuff like lights, wiring loom, HVAC unit, dash skin etc A wheel to steer the front of the car A pedal to steer the rear |
03-26-2013, 01:49 PM
AE86 weights list
i will see what i can do tonight.
got my scale noteboke with me for when i go to the shop |
03-26-2013, 05:01 PM
AE86 weights list
robokill Wrote:I think an empty hachi will never go below 800 kg. even with all plastic windows and other body panels. But ok, Lets see where this will take us. They'll weight mine before they take the blacktop out, and then after they put the SR20DET in AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
03-26-2013, 06:30 PM
AE86 weights list
That would be good data.
Like the CA18DET, the SR20DET is a 60kg penalty even before you start adding the oil cooler, intercooler and blow off valve necessary to run it on track. Seeing as you now have those parts sitting in your living room ;-) As a data point: my street legal Trueno, with CA18DET, fully stripped, racing seats, no cage: weighed in at 1040kg. A wheel to steer the front of the car A pedal to steer the rear |
03-26-2013, 06:50 PM
AE86 weights list
This Thread is great,
got some Specs for your list Flywheels, Source Google: Stock: 8.6kg Exedy: 8.9kg/ also available with 4.9kg (dunno why one of them is heavier than the oem ) XTR: 4.5kg XTD: 4.1kg F1 Racing: 4.5kg Fidanza: 3.7kg Toda: 3.7kg TRD: 5.5kg Engine, Gearbox, source Google: Nissan CA18DET: 128kg Nissan SR20DET: 139kg Nissan SR20DET Gearbox: 44kg Nissan RB25DET+Gearbox: 302.5kg Nissan VH45: 230.4kg Toyota 2JZ-GTE: 269.4kg |
03-26-2013, 07:39 PM
AE86 weights list
NoHachi Wrote:As a data point: my street legal Trueno, with CA18DET, fully stripped, racing seats, no cage: weighed in at 1040kg. Why I chose an E7... most models come in around/under 1000 kg For example... my E7 sport coupe body, as a 1600GT (2TG power), is listed as 975kg Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-26-2013, 07:54 PM
AE86 weights list
Well, if you removed the handicap called CA18DET it would have sat at roughly 975kg for a stripped 4AGE hachi with all fluids. So pretty similar.. it would have been quite a lot slower too though.
I'm not seeing big sources of weight differences between the E7 and E8 models. Same chassis, similar panels, engine = same, glass is very similar. Rear axle = same. I think they are a similar starting point, give or take a percent or two. A wheel to steer the front of the car A pedal to steer the rear |
03-26-2013, 08:06 PM
AE86 weights list
NoHachi Wrote:Well, if you removed the handicap called CA18DET it would have sat at roughly 975kg for a stripped 4AGE hachi with all fluids. So pretty similar.. it would have been quite a lot slower too though. chassis dimensions the same(similar)..... but the chassis is NOT the same... a number of supports the AE86 has that was not in the E7 line. Doors are not the same(no upper frame on long door E7) Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
