AGX dampers
08-13-2008, 04:33 PM
AGX dampers
No matter how hard i try i cannot read the partnumber on the boxes in teh picture..
08-14-2008, 09:53 AM
AGX dampers
I used the classic Camaro/SW20 AGX combination for my AE86.
The rears fit perfectly without any modification and are 8-way adjustable. The front inserts need some combination of shortening the strut plus spacers, to fit properly. They are 4-way adjustable from under the hood. For road use I have the fronts set on #2 from full soft, and the rears on #3. This works fine with my lowering springs, and gives a ride that is only slightly firmer than stock. And yes, AGX are a lot more expensive than GR-2 !!!!! Cheers... jondee86 |
08-14-2008, 01:16 PM
AGX dampers
Jondeed..
My prices are from KYB AGX themself. So SW20 inserts in the front will do the job? Got some numbers on them? That's what Eric wanted to hear. Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
08-14-2008, 04:13 PM
AGX dampers
Sx-Machine Wrote:Great.. But why 440 Euro?Because the shocks you can order are not AGX shocks: they are the "gas-a-just" shocks. They are not adjustable by yourself except by unmounting them like you normally would do with other shocks, like Konis for example. The rear AGX shocks are adjustable in 8 steps from the side of the shock and the front AGX shocks are adjustable in 4 steps from the top of the shock: so no difficulty in setting them up like with the Konis. The complete set is shortstroke, not longstroke. The rear set is Camaro and front set MR2, just like what Jondee86 has. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
08-14-2008, 04:20 PM
AGX dampers
found on the net:
90-95 SW20 MR2 front inserts part # 765015 and 82-02 Camaro rears part # 743019 costs for a set, through kybshocks.com of 2 times MR2 fronts and 2 times Camaro rears: $416.64. Retail price 214 and 196.74, apparantly discounted to about 50%. Well, hmm, dunno about shipping, so the AEU86 shop price is very reasonable and explainable. |
08-14-2008, 05:02 PM
AGX dampers
Banpei, are these the same partnumbers you have?
And cavey: (Y) |
08-14-2008, 05:15 PM
AGX dampers
I found the numbers posted on toyotanation by a person named hachi-roku in an AE86 related thread... but better make sure it's the right stuff I'm just assuming they're what is needed. Grin.
http://www.toyotanation.com/forum/archiv...318-1.html haven't checked the vague reference to club4ag yet. |
08-14-2008, 05:56 PM
AGX dampers
I assume nothing, i am waiting for banpei or someone else to confirm, thats why i opened this topic.
08-15-2008, 11:22 AM
AGX dampers
I chose the SW20 front inserts (KYB Part# 765 015).
Because I wanted to use normal lowering springs (not make a coilover conversion) I cut 40 mm out of the strut above the perch, and welded the threaded section back on. Then I made some solid aluminum spacers about 20 mm high to go under the inserts. The inserts came without KYB gland nuts, and the OEM nuts do not fit the AGX inserts. So I had to machine some material from the inside of the OEM gland nuts to make them fit on the AGX inserts. I also shortened the OEM rubber bumpstops by one segment to obtain a bit more compression travel. Cheers... jondee86 |
08-15-2008, 04:27 PM
AGX dampers
Eric Wrote:Banpei, are these the same partnumbers you have?I'll check them tonight. Edit: checked them and numbers are different! Front: 743019 Rear: 765015 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
Ae86 tein bonnet dampers? | irishboy1977 | 1 | 3,343 |
11-29-2011 01:28 AM Last Post: irishboy1977 |
KYB AGX part numbers | eight-six | 5 | 11,278 |
07-02-2009 11:16 AM Last Post: eight-six |
TRD blues front dampers | alex-evo | 3 | 5,124 |
10-16-2008 09:47 PM Last Post: jdm86gtz |
Which Camberplates do fit on Koni Yellow dampers? | AshCampbell | 41 | 36,127 |
07-02-2008 04:28 PM Last Post: AshCampbell |
Front dampers | totta Crolla | 3 | 4,416 |
11-16-2007 01:10 AM Last Post: oldeskewltoy |
