APEXi SAFCII on gZe???
01-13-2006, 11:47 AM
go to the "my car died on mer today" topic to discuss this :wink:
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
01-27-2006, 12:46 AM
NoHachi Wrote:Not if you are not going to do any serious tuning... Pretty soon I will have to get a new real gZe O2 sensor. Car still runs rich at low rpm and a bit lean at very high. Course i 'll have to go check how things are after I install the new O2. But... ![]() ![]() ![]() I have find a pretty cheap 1st gen APEXi SAFC (under 100 euros) and I like this device so much ![]() ![]() ![]() What do you guys think? No Hachi????? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
01-27-2006, 12:58 AM
Αre you sure that this thing works??
01-27-2006, 01:18 AM
Hiya,
I'm not sure of what the VFC will actually allow you to do, but if it allows some form of fuelmap alteration then it will be fine.. The point i was trying to make was about recognizing and keeping track of your actual fueling needs. Its kinda covered by the rest of the posts in the thread...maybe an example: First of all: a ordinary lamda is not a mixture meter, but a mixture gauge..The difference is that a mixture meter shows you the value of the mixture, while a gauge is more of a on-of switch. It switches at lamda =~1 and is pretty unreliable everywhere else.. Now the way I would tune a car, would be to hook up the WBO2 and start driving the car around while logging. You try and cycle through all load conditions and all rpm bands, continually logging the corresponding mixture. This could take up quite some time as there are many many different combinations that the car does not see very often..Its basically the way a car is tuned on a steady state dyno at the factory.. When you collect all the data after two weeks or so..the lambda number not only tells you how the mixture was, but also how much% fuel you have to add to get it to lambda=X..There are plenty of programs out there that calculate the efficiency of the engine from that data (VE-curve) and then accept a "desired" fuel curve as input and report back with the % changes that you have to make at each RPM/load intercept point.. Compare that to the usual "dyno"tuning procedure..A couple of runs through the gears (usually only at full load..thats just ONE of the 12 load settings that the ecu uses) and the corresponding 02 output.. Its a quick and dirty way of doing things, and could be fine, but nowhere near the accuracy that you could have with the other method.. Also a wideband cannot only tell you whether a mixture is lean, but whether it is dangerously lean..a nice precaution in any boosted car.. It also allows you to diagnose and spot any irregularities in the fueling of the car before they become a problem..kinda like the fuel pressure gauge. Now if you take that data, and tinker around with the AFC, I'm confindent that you would learn alot about the engine and tuning and produce a very good map in the process. The other method might work as well, it would probably be an improvement over what you have now. Its just that dyno time is very expensive..so a 200$ WB02 becomes a very attractive option. PS: datalogging=on any Laptop etc WBO2 has a narrowband simulation output that you can feed your ECU with..So ECU gets ordinary lambda signal, indicator on dash gets WB signal. A wheel to steer the front of the car A pedal to steer the rear |
01-27-2006, 11:06 AM
Very nice... Thanx for the info.
That's what I had in mind exactly. Get the Super Air Fuel Regulator wired up and then drive around with a WBO2 and a laptop connected to make it work right. Only difference with your words is that I was not planning to get a permanent WBO2 but just use one when data login the car... danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
01-27-2006, 11:16 AM
They are so cheap these days that, when you factor in the costs you have for a new ordinary O2 and dyno time, the WBO2 is almost cheaper..
Oh and if you really want to start pushing that little Eaton of yours, just let me know..I just heard what the little engine I made for the Formula Student car puts out without the 20mm intake restrictor..... It could theoretically power an AE86 now...same torque as well only at 12000rpm..(only a 1100cc difference in engine capacity). A wheel to steer the front of the car A pedal to steer the rear |
01-27-2006, 11:51 AM
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() But a factory gZe O2 sensor costs around 150 euros... Does this cheap WB02 Ivan mentioned is for data login and daily use? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
01-27-2006, 12:12 PM
Yes, the LC-1 lambdacontroller can simulate narrowband as well. You'll need to configure it though some software I guess, otherwise it will give weird signals (read that somewhere on innovate's forum).
Anyhoo...I wouldnt think twice about it...go for wideband! To top it all off: a bosch widebandsensor only costs 80 dollars at the moment, so if you ever need to replace the sensor again it's even cheaper than your narrowband! FABRICA MI DIEM, PVNC! |
01-27-2006, 12:25 PM
Ohyeah...one more thing..once you start to understand air/fuel ratio's etc better, I can almost guarantee you that you will want a full stand alone solution within a year...kinda gets addictive.
01-27-2006, 12:28 PM
Ivan141 Wrote:To top it all off: a bosch widebandsensor only costs 80 dollars at the moment, so if you ever need to replace the sensor again it's even cheaper than your narrowband! I havent change the sensor yet. So what do you propose? Go for a wideband instead of the stock gZe? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
DLI GZE no spark | 4agetercel | 5 | 7,219 |
02-01-2013 07:05 PM Last Post: 4agetercel |
GZE Swop with PAS & AC | Lauren | 12 | 14,185 |
02-16-2012 01:04 PM Last Post: heshan |
Engine sounds slush GZE with VIDEO ! | Okami | 13 | 15,063 |
01-03-2012 12:12 PM Last Post: Okami |
GZE swap in a SR5 | TomTom15 | 3 | 4,482 |
11-04-2011 12:30 PM Last Post: MatthewG |
GZE pulleys NEW question | Okami | 15 | 22,270 |
09-30-2011 07:08 PM Last Post: Lauren |
