Accelerator Pad part number?
01-30-2007, 01:46 PM
I´ve searched the EPC for the rubber accelerator pad without success. Theres only the bracket and adjacent parts, but no accelarator rubber pad.
Can anyone help me out? What part number? Its compatible with any other car? ![]() Cump´s Filipe Oliveira |
01-30-2007, 04:04 PM
i found som very well preserved pads on a junkyard, they were from the sedan version of corolla 1.3dx (same generation as hachi).
01-30-2007, 08:28 PM
I did the same search... what I believe is the pedal is ONLY available as part of the greater assembly. I've had this happen on other parts too... for example, you CAN'T buy original trailing arm bushings from Toyota, you CAN buy trailing arms and the bushings are pre installed, but you can not just get the bushing
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-31-2007, 12:04 PM
http://cgi.ebay.com/TOYOTA-CELICA-TA22-C...dZViewItem
Also check the store - interesting oldskull stuff |
01-31-2007, 06:26 PM
But no pedalpad.
02-01-2007, 12:23 AM
I've heard of people using the pads out of the MR-S. The only problem is if you want the gas pedal/accelerator pad, you have to buy the whole pedal assembly. Personally I still use the stock corolla gas pedal, but I switched out the brake and clutch pads with the MR-S one's.
| Quick question - Brake Pad Dimensions | Lt86 | 2 | 7,314 |
06-07-2015 12:08 AM Last Post: jondee86 |
| Something of interest to all suspension number crunchers | Bean | 1 | 5,619 |
01-05-2015 10:29 AM Last Post: Uzelac |
| Mintex brake pad MDB1193 | Dino86 | 9 | 12,523 |
02-27-2014 11:26 PM Last Post: Dino86 |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 8,481 |
| PART number to kouki trueno lighst | corolla4agze | 8 | 11,122 |
08-30-2010 05:04 AM Last Post: Ren64 |
![AEU86 AE86 - Accelerator Pad part number? [Image: AEU86 AE86 - Accelerator Pad part number?]](http://lipinhu.no.sapo.pt/sbanner.jpg)
![AEU86 AE86 - Accelerator Pad part number? [Image: AEU86 AE86 - Accelerator Pad part number?]](https://www.aeu86.org/sticker-banner-468.gif)
