Accelerator Pad part number?
01-30-2007, 01:46 PM
I´ve searched the EPC for the rubber accelerator pad without success. Theres only the bracket and adjacent parts, but no accelarator rubber pad.
Can anyone help me out? What part number?
Its compatible with any other car?
[Image: AEU86 AE86 - Accelerator Pad part number?]
Cump´s
Filipe Oliveira
01-30-2007, 04:04 PM
i found som very well preserved pads on a junkyard, they were from the sedan version of corolla 1.3dx (same generation as hachi).
01-30-2007, 08:28 PM
I did the same search... what I believe is the pedal is ONLY available as part of the greater assembly. I've had this happen on other parts too... for example, you CAN'T buy original trailing arm bushings from Toyota, you CAN buy trailing arms and the bushings are pre installed, but you can not just get the bushing
Dan -
01-31-2007, 12:04 PM
http://cgi.ebay.com/TOYOTA-CELICA-TA22-C...dZViewItem
Also check the store - interesting oldskull stuff Big Grin
01-31-2007, 06:26 PM
But no pedalpad. Undecided
02-01-2007, 12:23 AM
I've heard of people using the pads out of the MR-S. The only problem is if you want the gas pedal/accelerator pad, you have to buy the whole pedal assembly. Personally I still use the stock corolla gas pedal, but I switched out the brake and clutch pads with the MR-S one's.
  Quick question - Brake Pad Dimensions Lt86 2 5,348 06-07-2015 12:08 AM
Last Post: jondee86
  Something of interest to all suspension number crunchers Bean 1 4,060 01-05-2015 10:29 AM
Last Post: Uzelac
  Mintex brake pad MDB1193 Dino86 9 9,238 02-27-2014 11:26 PM
Last Post: Dino86
  Rear ae86 rear discs & pad part numbers? J-86 4 5,935 11-30-2012 06:32 PM
Last Post: J-86
  PART number to kouki trueno lighst corolla4agze 8 8,023 08-30-2010 05:04 AM
Last Post: Ren64
User(s) browsing this thread: 13 Guest(s)
