Adding O2 sensor support
01-10-2011, 05:49 PM
Currently I have installed a Cusco MFE ecu and it supports O2 sensor input.
Mine is a U.K spec. car and the stock ecu uses a potentiometer (VAF) to adjust mixture at idle and I think, cruise. It does not use an O2 sensor. I have disconnected VAF input to the Cusco ecu.
I have a wideband controller that can simulate a narrowband sensor and I have tried outputing a narrowband signal to the ecu but nothing changes with the idle mixture, it remains very rich.
The ecu throws up error code 5 which apparently is as you would expect "O2 sensor"
Is there more to this than simply connecting an output to the ecu ?
Thanks as always for any help
01-11-2011, 04:17 AM
Seems you may have to select "O2 input enabled" on one of the dip
switches ??
Cheers... jondee86
01-11-2011, 12:05 PM
Yes now I have some instructions for the ecu I know which switch does what function so I have tried enabling O2.
Do you know anything about grounding the sensor input ?
Can you tell me where the original O2 sensor grounds to, do you know if it is a pin on the ecu ?
01-12-2011, 12:07 AM
I'm shooting in the dark here... single wire narrow band grounds thru
the case, and the signal wire runs to a pin in the ECU. If you take a
simulated signal from an external controller, you will need the controller
grounded, preferably alongside the ECU grounds.
Cheers... jondee86
01-12-2011, 08:15 AM
i need a wideband sensor to adjust my Greddy ultimate too!
any suggestions ? i 've heard about innovate LC1 (sensor and cable-controller). How about that ?
ANy sites for low prices for that ?
Thanks
01-12-2011, 01:11 PM
Jondee you have a point there, I have grounded the controller at the case and there are two grounding pins in the 18 pin socket.
I will do a search to find out if I should use one of these and if any of the "spare" pins could also be grounds.
Alimonos, the Innovate is highly regarded for accuracy and I'm sure if you get a good one they are great BUT....
well have a read here:
http://www.innovatemotorsports.com/forum...ysprune=-1
It's almost as if Innovate have given up and now let people try to work it all out for themselves on the Forum Huh
In fact if I were you I would look for something that works out of the box, I have spent nearly as much time trying to get my Innovate stuff to work as I have spent tuning the engine, seriously.
01-12-2011, 11:26 PM
Yeah.... I have an Innovate LC-1, and it had a faulty controller right out
of the box. But once that issue was resolved (Innovate replaced the
controller) the thing has been rock solid. Faster than a speeding bullet,
and I can use a direct data output from the LC-1 to provide the O2 input
to my standalone.
So, a case of when they are good, they are very good... when they are
bad they are rotten !!!!
Cheers... jondee86
01-13-2011, 08:45 AM
totta Crolla Wrote:Jondee you have a point there, I have grounded the controller at the case and there are two grounding pins in the 18 pin socket.
Any suggestions ?
01-13-2011, 08:37 PM
Alimonos, sadly no suggestions from as I'm still trying to make my Innovate investment work but there are quite a few online reviews available, maybe best to do a search.
Good to hear a positive story about the LC-1 Jondee, could it be that the Innovate forum only attracts the problems ? that would be a shame if that were the case as potentially it is very good kit.
01-13-2011, 09:48 PM
Yes... I actually had read the threads in the Innovate forum before I
bought mine. But I figured having what is agueably the best and fastest
O2 controller around, outweighed the risk of getting a dud. Innovate
have sold huge quantities of kits, and the complaints that you read on
the forum represent only the tiny percentage that have a problem. The
other 99% plus that are working fine, don't write in.
I had to get an RMA# and return the kit to Felipe to get mine replaced.
But since then I have had zero problems. Can't say that is any comfort
to you, but I would certainly suggest emailing Felipe for assistance.
Cheers... jondee86
  Radiator & grill support panel (Levin) FanIsHere 5 2,185 11-14-2022 10:07 PM
  Lambda sensor wiring sam3007 10 4,649 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 20,525 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 8,409 02-28-2014 10:07 AM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,141 10-25-2013 05:13 PM
Last Post: Apsogos
