Adding O2 sensor support
01-10-2011, 05:49 PM
Currently I have installed a Cusco MFE ecu and it supports O2 sensor input.
Mine is a U.K spec. car and the stock ecu uses a potentiometer (VAF) to adjust mixture at idle and I think, cruise. It does not use an O2 sensor. I have disconnected VAF input to the Cusco ecu. I have a wideband controller that can simulate a narrowband sensor and I have tried outputing a narrowband signal to the ecu but nothing changes with the idle mixture, it remains very rich. The ecu throws up error code 5 which apparently is as you would expect "O2 sensor" Is there more to this than simply connecting an output to the ecu ? Thanks as always for any help An analogue brain in a digital World |
01-11-2011, 04:17 AM
Seems you may have to select "O2 input enabled" on one of the dip
switches ?? Cheers... jondee86 |
01-11-2011, 12:05 PM
Yes now I have some instructions for the ecu I know which switch does what function so I have tried enabling O2.
Do you know anything about grounding the sensor input ? Can you tell me where the original O2 sensor grounds to, do you know if it is a pin on the ecu ? An analogue brain in a digital World |
01-12-2011, 12:07 AM
I'm shooting in the dark here... single wire narrow band grounds thru
the case, and the signal wire runs to a pin in the ECU. If you take a simulated signal from an external controller, you will need the controller grounded, preferably alongside the ECU grounds. Cheers... jondee86 |
01-12-2011, 08:15 AM
i need a wideband sensor to adjust my Greddy ultimate too!
any suggestions ? i 've heard about innovate LC1 (sensor and cable-controller). How about that ? ANy sites for low prices for that ? Thanks AE86 FANATIC!!! |
01-12-2011, 01:11 PM
Jondee you have a point there, I have grounded the controller at the case and there are two grounding pins in the 18 pin socket.
I will do a search to find out if I should use one of these and if any of the "spare" pins could also be grounds. Alimonos, the Innovate is highly regarded for accuracy and I'm sure if you get a good one they are great BUT.... well have a read here: http://www.innovatemotorsports.com/forum...ysprune=-1 It's almost as if Innovate have given up and now let people try to work it all out for themselves on the Forum ![]() In fact if I were you I would look for something that works out of the box, I have spent nearly as much time trying to get my Innovate stuff to work as I have spent tuning the engine, seriously. An analogue brain in a digital World |
01-12-2011, 11:26 PM
Yeah.... I have an Innovate LC-1, and it had a faulty controller right out
of the box. But once that issue was resolved (Innovate replaced the controller) the thing has been rock solid. Faster than a speeding bullet, and I can use a direct data output from the LC-1 to provide the O2 input to my standalone. So, a case of when they are good, they are very good... when they are bad they are rotten !!!! Cheers... jondee86 |
01-13-2011, 08:45 AM
totta Crolla Wrote:Jondee you have a point there, I have grounded the controller at the case and there are two grounding pins in the 18 pin socket. Any suggestions ? AE86 FANATIC!!! |
01-13-2011, 08:37 PM
Alimonos, sadly no suggestions from as I'm still trying to make my Innovate investment work but there are quite a few online reviews available, maybe best to do a search.
Good to hear a positive story about the LC-1 Jondee, could it be that the Innovate forum only attracts the problems ? that would be a shame if that were the case as potentially it is very good kit. An analogue brain in a digital World |
01-13-2011, 09:48 PM
Yes... I actually had read the threads in the Innovate forum before I
bought mine. But I figured having what is agueably the best and fastest O2 controller around, outweighed the risk of getting a dud. Innovate have sold huge quantities of kits, and the complaints that you read on the forum represent only the tiny percentage that have a problem. The other 99% plus that are working fine, don't write in. I had to get an RMA# and return the kit to Felipe to get mine replaced. But since then I have had zero problems. Can't say that is any comfort to you, but I would certainly suggest emailing Felipe for assistance. Cheers... jondee86 |
Radiator & grill support panel (Levin) | FanIsHere | 5 | 2,191 |
11-14-2022 10:07 PM Last Post: Ivan141 |
Lambda sensor wiring | sam3007 | 10 | 4,650 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,536 |
Hall sensor | totta Crolla | 7 | 8,411 |
02-28-2014 10:07 AM Last Post: Ivan141 |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,149 |
10-25-2013 05:13 PM Last Post: Apsogos |
