Ae92 gti flywheel on t50
12-31-2007, 12:30 AM
Does it fit? or do i have to buy a new one. its from the year 88
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
12-31-2007, 01:10 AM
Should be the exact same flywheel as the ones on the ae86 4age's.. so yes..just use it.
12-31-2007, 02:27 PM
Ivan141 Wrote:Should be the exact same flywheel as the ones on the ae86 4age's.. so yes..just use it.
Don't there is a problemes with the bolts...?
Or it's change on the redtop higt compression?
SR Team
BURN THE RUBER NOT YOUR SOUL!
12-31-2007, 02:38 PM
I think that flywheels dimension changes 200->215mm on 1989-90 when head changes bigport to smallport, also clutch covers dimension changes, but 212mm flywheel fit on T50 -bellhousing.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
12-31-2007, 03:50 PM
I use 212mm flywheel and I'm pretty happy with the bigger clutch.
AE86 GTS '84 Red Top
12-31-2007, 04:46 PM
Thanks alot Big Grin im very happy now Tongue dont need to buy a new one.
12-31-2007, 04:54 PM
With AE92 GTi flywheel also you need AE92 GTi cluch.
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
12-31-2007, 05:25 PM
i bought an ae92 clutch and mounted it on my 4a-c engine
12-31-2007, 06:39 PM
No need to overcomplicate the answers guys.. the '88 model engines are bigports so the flywheel is the same as the ae86 type, which also means that the clutch plate and cover are interchangeable.
01-01-2008, 12:50 AM
In Australia the AE92 GTI was only sold with the 100kw smallport engine
the only difference to 4AGE SX was the trim internal and extenal
So really it should only be biased on the type of 4AGE that the flywheel came off , Big port or Small port
Difference between the two on the flywheel is the clutch plate surface area and the bolt / dowel locations so you can use both in the T50
  T50 gearbox totta Crolla 3 2,512 02-25-2022 02:35 PM
Last Post: Project D
  T50 TRD gearset DidiDex 7 9,063 09-12-2019 07:36 PM
Last Post: DidiDex
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,525 04-20-2018 09:14 AM
  light weight Flywheel filh 9 7,334 02-05-2018 05:20 PM
Last Post: filh
  crank 6 bolt flywheel DJexor 5 8,115 12-05-2016 08:21 AM
Last Post: d3nso
