Ae92 water pump same as ae86????
12-04-2007, 10:40 PM
Just as it says..
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
12-04-2007, 10:52 PM
according to the EPC it's not the same
AE86 part# 16100-19095
AE92 (4age) part# 16100-19115
if you need one, you can get it there pretty cheap
http://www.markenautoteile.de
12-04-2007, 11:28 PM
I have put a AE92 front part in to AE86 rear part. They will fit together.
Whole pump assy is different from the rear.
Here is a AE92 water pump
[Image: AEU86 AE86 - Ae92 water pump same as ae86????]
and here is AE86 water pump with AE92 front part
Oh, I almoust forgot. Front parts has different lenght. AE92 front is couple of mm shorter, so if you use a AE92 front part with RWD pulleys, you need spacer.
Quote:[Image: AEU86 AE86 - Ae92 water pump same as ae86????]
I found that the water pump I have is from an AE82 and slightly shorter than the AE86 pump. My brother is a wizard with the lathe and made a small spacer plate to align the pump pulley with the other two;
All the pulleys now line up nicely;
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
12-05-2007, 06:03 PM
If you use an AE92 pulley you wont need a spacer to make it line up.
The main reason that the AE86 pump is longer is that it has a bigger bearing. Probably designed this way because the AE86 has a mechanical fan attached to it..this increases the stress on the bearing. I have been using an ae92 pump for a long time with no problems, but I've seen pictures of pumps where the front had broken off completely, so it's up to you if you want to use one or not.
12-05-2007, 10:16 PM
thanks everyone.
I wonder isnt it better then to have a electric waterpump.
  20v BT - which oil pump? Mylesmck 4 2,921 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 5,446 04-29-2022 05:45 AM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,813 12-06-2017 06:48 PM
  fuel line hose from the pump Wikizz 4 6,156 10-16-2017 07:11 PM
Last Post: jdm86gtz
  20v conversion water relocation izanagi 1 5,531 06-15-2016 09:45 AM
