Air Inlet Piping Problem
07-13-2009, 03:58 PM
Hi guys Smile
I took all the piping out from my engine but I did not remember where they connected. I am going to put a pic of piping which I remember. If you can draw st on the pic it would be awesome Smile
[Image: AEU86 AE86 - Air Inlet Piping Problem]
http://www.ae86tr.com
07-13-2009, 04:58 PM
One is supposed to go to the fuel pressure regulator at the back of the fuelrail (dont see it in your pic), one goes to the map sensor (which is also not visible in your picture), and the last one passes somewhere around the back of the inlet manifold, probably towards the TVIS system.
07-13-2009, 05:33 PM
MAP sensor? would you mind to show the pics of it so i can find it inside of the engine bay
07-13-2009, 06:29 PM
I found the missed part of mine
What is this part. I restrored my car but mine is lost...
What is it for and where is it connected? And how can i fidn it what is the name of this part?
07-13-2009, 06:56 PM
That's the switch for the power/econ light in your dashboard. Just plug it if you dont have it anymore.
07-13-2009, 07:02 PM
where should I have to connect it?
07-14-2009, 03:39 PM
BUMPY
07-14-2009, 09:03 PM
Where should you connect what? The econ light switch is a useless accessory, I think it's just one wire that connects it to the loom. Like I said, you can just plug the vacuum line of with a screw or something.
  Fitting Air Con (No PS) to LHD AE86 pack 7 4,333 01-07-2024 11:36 AM
Last Post: CCB
  Smallport inlet manifold totta Crolla 6 3,550 01-17-2022 05:14 PM
  Air Cleaner Assembly Hama86 7 9,501 10-29-2018 03:28 AM
Last Post: Hama86
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 17,702 08-16-2018 01:36 AM
  Bluetop AFM with air filter izanagi 4 7,181 04-29-2016 07:29 PM
