American Rally 86 UPDATE
01-28-2008, 05:45 AM
And here are some more pics...
This is the axle after some clean up ![]() ![]() Basically, I've just cut off the stock 4 link brackets but left the pan hard and sway bar mounts. I've also been grinding the remains down to the axle level and wire wheeling away the rust. It was only a lot of flakey surface rust, so nothing too bad ![]() Heres the "artistic rally parts shot" haha ![]() Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
01-28-2008, 08:49 AM
Nice project! Thats going to be a sweet rally car
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
01-28-2008, 10:47 AM
Thanks! I forgot to make a general overview of whats going on, so here's one!
Engine: Port blended small port head with over sized intake and exhaust valves Web Racing cams, Grind 110- 256 duration at .050 lift. The lift is a little over 10mm. Toda valve springs Shimless buckets Wiesco forged aluminium pistons, 12:1 compression Balanced internals No idea about the flywheel or clutch yet. All I know is I want a 4 puck cerametallic disc. Fully deburred block GSX/R 600 throttle bodies No idea about exhaust yet. I think I may just pull a Group A and bore out the stock manifold and the down pipe... allthough to save wieght, I might just dish out some money for a nice header Transmission: For now, just the stock T50, I'll see how that does and/if/or I break it, I'll get a Ford Sierra's Type 9 with a close ratio gear set Rear Axle: Celica Supra axle with a 5.3 final drive and LSD Brakes: Eventually will be Dual master cylinder set up with a hydraulic handbrake. Wilwood powerlite calipers in the front Wilwood 2 pot dynalites in the rear 10x.810in (254x20.57mm) discs up from, slotted and vented Stock supra rear discs, 10x.38in (254x9.65mm) flat unless I can find slotted and solid rotor Body and chassis: Seam welded from strut towers to turrets Rear turret kit Full roll cage Lowered seat mounting postions Suspension: JVAB 40mm Bilstein based coil overs Reinforced lower control arms Equal length extended 4 links (aiming for around 30 inch (76.2 cm) links without the length of the rod ends Cage reinforced front strut towers Fuel and Ignition: Duel electric fuel pumps Fuel Safe 15 gal fuel cell, enduro Autronic or Haltec ECU Some form of CD ignition, maybe MSD Push button ignition Optima red top battery Master cut off switch Interior: Sparco Corsa seats Custom carbon fiber dash Custom gauge set Custom CF pedal kit (heel toe & LFB better!) Undecieded racing wheel w/ two buttons (either stock or added buttons) for killswitch and horn That should be most of it, I'm sure I'll remember some more later. Also, I'll try to get the newest version of the cage uploaded (I've designed it in 3d) And, I'll get the pictures taken of my 4 link mock up and the work I did today on the floor. Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
01-28-2008, 11:48 AM
Wow... That's a huge project!
![]() The rear axle is Celica Supra Mk1? ![]() Thought that Mk2 had IRS like the AA63. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
01-28-2008, 07:53 PM
Hi! I like the way you went to work on that coupe, no holds barred! Keep up the welding, I'm sure you'll learn to do great welds in no time, otherwise, check this site out for informative instruction video's: http://www.mig-welding.co.uk
Looks like you used to a bit too little shielding gas, or maybe worked in a windy area. Keep us updated! FABRICA MI DIEM, PVNC! |
01-28-2008, 09:09 PM
It was actually the wrong gas
![]() And the axle is from the 79-81 celica supra, so I think mk1? I've been slightly kicking myself for not seeing how hard it would be to swap on a later gen's IRS onto the car. Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
01-28-2008, 10:20 PM
Yeah, that's the Mk1 alright.
01-29-2008, 04:05 PM
nice build, im very jealous that you have a coupe, id much rather one.
So, i have the same problem with my cage being in the spot the blower mounts...soo, do you want to attempt it first or should I? ![]() is this going to be a gravel rally car or a tarmac? ah how i want to lighten mine up with lexan and fibreglass panels...but not allowed ![]() |
01-29-2008, 10:32 PM
Well, I've pretty much realized that I need an aftermarket heater... so thats what i'll be running. As for the type of rally car, it will be gravel spec, as not many tarmac rallies are run around here. However, it will see its fair share of any event I can afford at the time
03-28-2008, 08:14 PM
[SIZE="5"][COLOR="Red"]
Heres a bit of an update... Ask questions if you want I'll answer Ok, these are the strut tower reinforcements. The plate on the side is for the roll cage tubes that come through the firewall. (Take that Jesse! haha) The other peices are to help with the constant pounding the tops will take. ![]() ![]() ![]() These are the 30 inch links... There are also some shots of the brackets (I'll get better ones later) ![]() ![]() ![]() ![]() Here is the rear turret. I've only got the right side done so far ![]() ![]() And the boxed control arm ![]() [/COLOR][/SIZE] Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
AE86 N2 (big update) | 86Pilot | 110 | 139,380 |
09-06-2013 11:33 AM Last Post: Apsogos |
86er's Track rebuild N2.??? Finally an update page 8 | 86er | 191 | 261,469 |
Supercharged Hachiroku "update" | roadrunner | 20 | 24,610 |
06-02-2011 03:27 AM Last Post: kennedy8383 |
AE86 two door 1987. in restoration, in Iceland UPDATE | olithor | 12 | 21,404 |
08-08-2009 12:36 PM Last Post: rs1800 |
AE86... update 25/06.. car might be for sale | Eiwiss | 57 | 66,302 |
08-01-2009 03:16 AM Last Post: rymax86 |
