Anyone running DIY Coilovers?
11-19-2013, 12:20 AM
Hi,
Is anyone running DIY coilovers? What's your spec?
I'm planning to buid mine and until now the choices i made are the following:
- TRD shocks front and rear (48511-AE881 & 48531-AE881), 188 mm stroke
- Eibach Springs 39 N/mm or 44 N/mm, 8" (203 mm) or 9" (228 mm) long, 57 mm ID (2,25")
- Helper springs
It's about the springs that i have some doubts because i can only use 39 N/mm rate with 8" long (or 44 N/mm). With 9" long i can only use 44 N/mm rate.
Are 8" length springs long enough or should i go to 9" with 44 N/mm (Frequency will go higher of course)?
Thank you for your help.
Keeping the AE86 alive!
11-19-2013, 12:52 AM
I'm running AE86 suspension on my KE20 with 2T-G (910kg curb weight).
- Tokico HTS short stroke inserts on shortened housings.
- RallyDesign springs 325 Rate (google tells me, this should be 4,4 kg/mm), 10,5" Free Length, they are quite long, as i have the threaded bit sitting a bit low on the housing, because i was afraid of damaging the threads for the gland nut.
[Image: AEU86 AE86 - Anyone running DIY Coilovers?]
If you can get the threaded bit a bit more upwards then i did, i'd say 8" springs would be good enough, otherwise a set of springs from RallyDesign (2,25" inner diameter) is 30 pound.
I'm running without helper springs.
11-19-2013, 11:16 AM
Thanks.
About your spring rate i think it's higher than 4,4 Kg/mm.
1 lb = 0,45359237 kg
1 in = 25,4 mm
0,45359237 / 25,4 = .017857967322834645669291338582677
So 1 lb/in = 0,017857967322834645669291338582677 kg/mm.
325 lb/in = 5,8 kg/mm
Anyone else has DIY coilovers?
11-19-2013, 11:18 AM
Teach a man how to fish etc..
http://performance-suspension.eibach.com..._worksheet
MotionRatio (MR): 1
ACF-front: 0.99
MR rear:
d3(shocks/coilovers) =1135
d3(spring-perches) = 900
d4 = ~1345
That should be enough to get this thing figured out.
11-19-2013, 05:40 PM
Hi NoHachi,
I've already made some calculations and read your old post about suspension.
I'm using the unsprung weight values you wrote somewhere (35Kg/side at front and 100 Kg at the rear).
What D3 do you use? I'm using the spring ones, not the shocks...
11-19-2013, 06:17 PM
Rasteirinho Wrote:Thanks.
1 in = 25,4 mm
ah yes, you're right... I always mix lb/ft and lb/in in this situation Smile
11-19-2013, 10:04 PM
Rasteirinho Wrote:Hi NoHachi,
You use the D3 value that is correct for your springs.. when running rear coilovers use the one where the shocks (and now also the springs) attach.
11-19-2013, 10:30 PM
Your TRD front dampers will work really nicely with 225lb springs
and something like 190lb rears.
  No idle below 2000 rpm rich running Steller Engineering 3 1,436 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 2,769 06-26-2022 01:34 PM
Last Post: Dave W
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 7,255 11-09-2020 10:51 AM
Last Post: totta Crolla
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 6,213 06-05-2017 10:03 AM
Last Post: nyberrg
  Fitting driftworks CS2 coilovers bozu 2 4,637 05-30-2017 10:50 AM
Last Post: bozu
