Aram's 3SGE Beams Levin Coupe
05-21-2012, 01:33 PM
Post: #421
you are doing a good job of this
but why do you guys change the rubber joints in the 4 link rear end with nolathane bushes ,all this does is lock up the rear end and stops it from working in a arc like it should
.as even in my race car i still use rubber at the back
05-25-2012, 06:57 AM
Post: #422
The urethane joints should have enough give IMO, it's rose-joints (heim joints) that lock up the rear ends on these and prevents them from articulating correctly.
Although roll center/ride height, spring rates and sway-bars also affect whether there will be bind or not.
Andrew
05-25-2012, 12:02 PM
Post: #423
well andrew take your car to the track and race it around with the nolathane and then tell me ,,actually rose joints give a better arc of movement than nolathane does
most of the old group c race cars used rubber 4 link rear ends and also had rose joints link arm along side the originals
05-26-2012, 05:28 PM
Post: #424
Celica RA45, its a matter of what you prefer.
You seem to prefer rubber where most people go to Urethane simply because its a bit stiffer not as hard as a ball joint. I have driven both and I really liked the Urethane ones. I agree that using the stiff balljoints messes up the traction.
05-27-2012, 02:35 AM
Post: #425
if its for a race car on dot race tyres like re55 ao50 etc ,the rubber bushes win every time
on full on race cars with slicks ,rod ends or rose joints win every time
on tight twisty tracks rubber is better for traction out of corners
nolathane is ok for boy racers or ricing up cars
07-02-2012, 08:37 PM
Post: #426
I was told to update, so....
Because I have a different engine in my car all the hoses won't fit anymore.
To solve this I to have some hoses made.
This is possible but you have to make moulds for them, which I did.
It looks easy but it quite a bit of work to get them right.
A beginning:
[Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]
And finished items.
These get sent to SFS and then after a few weeks you get this:
Pretty nice huh. Smile
The battery holder is done:
07-02-2012, 09:13 PM
Post: #427
Then one of the last major parts was to be made.
We start with a box full of this:
And then we go about making the already modified (see previous updates) exhaust manifold a bit bigger:
07-02-2012, 09:20 PM
Post: #428
And a bit more...
As you can see it is nearly done. Smile
07-02-2012, 09:25 PM
Post: #429
Also the radiator shroud was finished:
And I got me a nice radio with old school look:
It was not working properly due to a broken track on the printboard.
With the help from a great guy from New Sealand I found out where the problem was and fixed it!:
07-02-2012, 09:46 PM
Post: #430
Porn Porn Porn...
After all this I can only hope that it's exterior and interior will do the craftsmanship justice.
  ae86 racecar with beams engine bakonick 148 162,971 04-23-2024 10:06 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 88,119 05-07-2019 09:35 PM
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,715 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 158,882 03-28-2018 12:35 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 603,888 06-27-2017 12:21 PM
Last Post: DJexor
User(s) browsing this thread: 17 Guest(s)
