Aram's 3SGE Beams Levin Coupe
11-25-2012, 02:37 PM
Post: #501
Right, some things I did:
I moved the side indicators into the citylight housing:
[Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]
And checking to see if it works:
I broke of a plastic hosepipe, so that meant more work. I made a new one from aluminium:
I was told the original AE86 reverse light sensor would fit in the Aisin 6 speed gearbox, but guess what, more work.....
Almost all windows are in the car now, only the left rear side window needs to be placed, it was not to my liking the first time around.
I also algined the doors and I wrapped the b pillar flat black:
Front window is in, it has two seperate sides heated, it's a rallycar version.
11-25-2012, 02:46 PM
Post: #502
Ohh, and here is one window that got away......
One of the last things to be done is the airbox, which is alot of work.
I myself think a panel filter is always better than a mushroom one, so I asked a friend to build me one.
These is what he came up with:
11-25-2012, 02:57 PM
Post: #503
Placing the maf sensor is pretty critical for a BEAMS, and getting a housing for the sensor is difficult aswell.
I finally got my hands on a original filter housing, and used parts of it for my own airbox.
I wanted hear the engine running again so I hooked it up like this, but it wouldn't run stationary:
Above a 1000 rpm though it ran like a dream Smile
But back to the box:
And yesterday I had it welded up:
Now it is back at my friends place to be finished, he will be making a labyrinth inside for better airflow and low turbulance at the maf sensor.
11-25-2012, 09:05 PM
Post: #504
One more thing I did is reroute the loom on the engine.
It was not how I wanted it to run so I needed to change.
Plus I used vulcanizing tape now, so it looks alot nicer too Smile
And an overal view as it is now:
11-25-2012, 09:52 PM
Post: #505
Thumbs up! Respect! Respect! Respect!
11-25-2012, 11:29 PM
Post: #506
Clean as F#CK! Thumbs up!
11-26-2012, 02:51 AM
Post: #507
have you run the cables yet?
11-26-2012, 10:10 AM
Post: #508
About the airbox: does it offer easy access to the panel filter? I can imagine it being a pain to dissasemble the whole box from the car every time you need to change filters.
11-26-2012, 07:46 PM
Post: #509
McKenney,
Yes I have, still need to make pictures. Wink
Ivan,
The top half of the box comes off like a regular airbox, so relative easy access. Smile
12-21-2012, 08:19 PM
Post: #510
Right, the ecu needed a place to stay, but it was 1.5 times bigger than the 4age one.
A bracket was needed:
The heater fits in it's original position, no pics yet of that, but I'm satisfied. Smile
I always disliked the lock on the feultank door, so I purchased a nice cable assembly from Mr McKenney.
Now I can open the boot and tank door from the inside!
  ae86 racecar with beams engine bakonick 148 162,971 04-23-2024 10:06 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 88,118 05-07-2019 09:35 PM
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,715 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 158,882 03-28-2018 12:35 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 603,887 06-27-2017 12:21 PM
Last Post: DJexor
