Bad gas milage
05-29-2005, 07:11 PM
Bad gas milage
You could also check the oxygen sensor. Co2 must have a value between 0,5 and 1,5. If you have a higher co2 then you spoil petrol.
Succes, mine had (4%!!!!).
05-29-2005, 07:43 PM
Bad gas milage
Hmmz you can adjust it yourselves the yellow slut had it as well on MOT 3%
i turned it back to 1.5 % :-) helped in millage as well
08-18-2006, 07:22 AM
Bad gas milage
What is the yellow slut?
Regards
Andrej
08-18-2006, 09:36 AM
Bad gas milage
dreja, I believe it was the car robokill bought about 2 years ago and then parsed on to the theprez. The car got its nickname cause of its very interesting yellow paint I guessBig Grin
08-18-2006, 01:11 PM
Bad gas milage
Tnx Smile
I thought robokill used the name for some kind of adjusting screw Smile
Regards
Andrej
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 1,169 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 29,678 06-27-2018 11:15 PM
Last Post: Ryo
  Bad vibrations /resonance starts at 5000 rpm izanagi 7 8,512 07-23-2015 05:02 PM
  bad coolant kawo 9 11,479 11-18-2013 07:43 PM
Last Post: Apsogos
  3rd door support gas springs (stay) - worn out max_ae86 5 6,286 09-01-2013 03:20 PM
Last Post: Jezza_hr
