Bad gas milage
05-29-2005, 07:11 PM
Bad gas milage
You could also check the oxygen sensor. Co2 must have a value between 0,5 and 1,5. If you have a higher co2 then you spoil petrol.
Succes, mine had (4%!!!!). |
05-29-2005, 07:43 PM
Bad gas milage
Hmmz you can adjust it yourselves the yellow slut had it as well on MOT 3%
i turned it back to 1.5 % :-) helped in millage as well Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
08-18-2006, 07:22 AM
Bad gas milage
What is the yellow slut?
Regards Andrej |
08-18-2006, 09:36 AM
Bad gas milage
dreja, I believe it was the car robokill bought about 2 years ago and then parsed on to the theprez. The car got its nickname cause of its very interesting yellow paint I guess
![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
08-18-2006, 01:11 PM
Bad gas milage
Tnx
![]() I thought robokill used the name for some kind of adjusting screw ![]() Regards Andrej |
ClutchMaxPRO Clutches - Good or Bad? | RolanTHUNDER | 0 | 1,294 |
12-01-2022 09:55 AM Last Post: RolanTHUNDER |
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 30,963 |
06-27-2018 11:15 PM Last Post: Ryo |
Bad vibrations /resonance starts at 5000 rpm | izanagi | 7 | 8,786 |
07-23-2015 05:02 PM Last Post: Bean |
bad coolant | kawo | 9 | 11,727 |
11-18-2013 07:43 PM Last Post: Apsogos |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,475 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
