Banpeis project
01-31-2007, 08:12 PM
Post: #301
Banpeis project
Yeah that's good! I wonder if those "steekproeven" are really at random or if they where just curious to know what kind of old Toyota this was...
02-01-2007, 04:52 PM
Post: #302
Banpeis project
I think it is more or less dependent on the reputation of the MOT station. When I asked them how many times they get one the answer was: "Atleast two times per week, sometimes twice a day" so I think their reputation is not so good.
02-19-2007, 10:55 PM
Post: #303
Banpeis project
Maybe too fanboy, and maybe completely useless on Dutch roads, but I already have a dash switch reserved for it to make it silent again. I've finally received Ian.G's dinging device!
Thanks Ian! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-20-2007, 12:02 AM
Post: #304
Banpeis project
Hmmmz will it keep dinging ? god I would go crazy just driving ;-D
02-20-2007, 01:04 PM
Post: #305
Banpeis project
robokill Wrote:Hmmmz will it keep dinging ? god I would go crazy just driving ;-DThat's what the switch is for. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-20-2007, 01:15 PM
Post: #306
Banpeis project
HEY! I have one too!
(but I couldnt get it to work ) still no 86 ________________________ |
02-20-2007, 02:01 PM
Post: #307
Banpeis project
Blueneon Wrote:HEY! I have one too!I can make a recording for you and send it to you on cd. > But does your gauge cluster have a speed-signal? If so I guess it should not be too hard to do something with it. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-20-2007, 02:03 PM
Post: #308
Banpeis project
Btw banpei, can't you do something to change the switch point on the speed signal? Make it go ding ding ding at 120kph? Or at whatever odo speed at which you're actually going 120kph? then the thing would actually be usefull
Might be the case of just adding a little variable resistor... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
02-20-2007, 04:05 PM
Post: #309
Banpeis project
Hey Art,
glad it came through to you. I'm glad you are fitting a switch to disable it - that thing drove me insane when I had to drive 200kms with it still in at motorway speeds. Its just as well the ITBS and stuff were loud enough to block out most of the noise. I reckon you are right - a variable resister of some sort would probably mean you can have a dial where you can adjust when it kicks in. I'd measure the change in volts/amps across the connector and see if they are speed related. Regards Ian. |
02-20-2007, 11:34 PM
Post: #310
Banpeis project
that dingy drove me crazy after a week... i disconnected the wire... any track day and highway its sucks so bad
