Battery died. Headlights now go up but not down.
09-13-2008, 03:39 AM
Hi Everyone,
I have a Trueno that was converted from a Levin. All along the headlights would pop up and go down when I use the light switch. However, a few days ago the battery died. Because I was parked in an awkward spot I took the battery out to charge and then put it back in when fully charged. The car started and ran fine but the headlights now only pop up and do not go down. I've checked all the fuses and they seem fine to me, but I can't figure out what's the issue. Would anyone have any ideas please? Thank You! |
09-14-2008, 12:31 PM
Sounds like a relay issue to me mate, you may want to locate the relays and give them a well needed tap.
Failing that it could be your switch. Do you have the original light switch (Levin) or the Trueno one? They have a difference between them where the Trueno one can be pushed in to keep the lights up. |
09-14-2008, 04:53 PM
I'll locate the relay and give that a go. Thanks for the reply mate
![]() And I have the trueno light switch where I can push it in and go to the right once more. |
09-15-2008, 01:18 PM
Maybe the retractor unit has gone bad and thinks it should popup all the time... Check the input of that unit, since it gets feed from both the lightswitch and the highbeam.
1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Engine starts/revs but no idle | GenkiMotors | 17 | 8,149 |
AE86 Battery specs | hachirokuGTV | 9 | 17,398 |
LHD VS RHD headlights (Levin) | Lt86 | 2 | 4,764 |
02-28-2017 12:08 PM Last Post: zenki |
Carb conversion but what is this and how ? | Allexz | 5 | 8,776 |
05-24-2016 08:48 AM Last Post: Allexz |
Dancing headlights..... | pack | 0 | 3,590 |
10-16-2015 03:18 PM Last Post: pack |
