Best modification
03-04-2008, 06:27 PM
Best modification
I've just completed the best modification so far to my '86
Quaife close ratio Ford type 9 gearbox with a TRD clutch, it's fantastic ![]() The car seems to come alive with a close ratio gearbox. It really suits the power output of even a standard 4AGE Strangely it's not a very common mod though.... An analogue brain in a digital World |
03-04-2008, 07:31 PM
Best modification
how about costs ?
![]() AE86 FANATIC!!! |
03-04-2008, 08:13 PM
Best modification
alimonos Wrote:how about costs ?Scary yes, but probably less than a 20v conversion. I think it gives a comparable increase in performance. The noise is unbelievable, she wails like a banshee now ![]() OK though, 'cause it's a rally car ! An analogue brain in a digital World |
03-04-2008, 08:19 PM
Best modification
I´ve heard that.
Its a shame that a close gear ratio set is so damn expensive. ![]() Cump´s Filipe Oliveira |
03-04-2008, 08:54 PM
Best modification
Lipinhu Wrote:I´ve heard that.Yes the T50 Toyota gearset is very expensive and rare but a used Ford Type 9 is not too bad price wise and fairly common. I think a complete conversion could be done for around 1200 euros. Here are a few money saving tips: Find a used Type 9 CR (Quaife or Tranex) on that auction site. (600) Use a standard AE86 clutch cover and a MGB clutch plate. (50) Modify standard gearbox mount, easily done (20) Modify standard release (throwout) bearing, just bore it out to fit Type 9 shaft (20) Modify front half of propshaft to fit Ford output shaft (100) Get Raw engineering bellhousing and spigot bearing (300) Put it all together ![]() Numbers in brackets are approximate prices in Euros, my computer does'nt have a Euro key !!! An analogue brain in a digital World |
03-26-2008, 11:02 AM
Best modification
totta Crolla Wrote:I've just completed the best modification so far to my '86 It is also my best modification as well. I have TRD close ratio gearset in my T50 gearbox. It works really well with my 4agze. I love the long first gear it let me take advantage of the torque from the supercharger. I can almost do 80km/h in first! snap into second and there is hardly any drop in rpm and you just continue to accelerate oh yeah and the noise is cool too :mrgreen: |
05-15-2008, 04:48 AM
Best modification
Why not just go for a pinion and drive set?
05-22-2008, 08:53 PM
Best modification
Hmmmm.... I can't wait till the LOOOONG AZ6 project is done(going on 22 months now)....
![]() totta Crolla Wrote:The car seems to come alive with a close ratio gearbox. It really suits the power output of even a standard 4AGE I expect similar results!!!! Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-22-2008, 10:08 PM
Best modification
Wow...must be really expensive to get that bellhousing/front gearbox houding milled out of such a huge chuck of aluminum
![]() FABRICA MI DIEM, PVNC! |
05-23-2008, 02:00 AM
Best modification
The hunk of aluminum is $170.00 the CC time was about $1000 (first run no program). There are some necessary minor machine work the box still needs... but the case for all essential purposes is done......
I expect more soon..... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
which is the best quality flywheel brand for 4age smallport? | LyndonAE86 NZ | 8 | 13,617 |
12-06-2012 01:20 AM Last Post: Bean |
Best thing I have done to my car yet! | phill 92 | 7 | 7,948 |
07-16-2012 02:19 PM Last Post: gt4st205 |
Best country to import "rust free" ae86? | EJ20 | 6 | 7,585 |
03-27-2012 06:57 PM Last Post: zenki |
Best paint color for the 86? | heshan | 12 | 13,297 |
06-15-2010 10:51 PM Last Post: sergiocharged |
Best choice for stability... | Serencebey | 8 | 7,014 |
03-17-2007 10:53 PM Last Post: NoHachi |
