Brake fading
08-08-2007, 12:22 PM
Brake fading
I normally don't brake hard since I use my hachi for daily driving and drifting.
Last week I went driving on a "touge" and went full out. After 15min or so, on the way back down I was braking and shifting down to second when I notice that the pedal is almost on the floor, but the car isn't slowing down as it should be. Quite scary because it was a tight 180degree turn. ![]() This is what I got: New stock pads Old disks, but in good shape. New dot4 brake fluid New Goodridge lines. Any advice to make the brakes better? |
08-08-2007, 01:34 PM
Brake fading
Start searching cheap RX7 4-pots. No joke.
08-08-2007, 02:41 PM
Brake fading
You could our mintex pads:
http://shop.aeu86.org/index/products-bra...topic=4449 Where did you find a touge in Holland btw? > ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
08-08-2007, 03:10 PM
Brake fading
Banpei, Limburg rules man!
I won't repeat what my partner said other then that i'm going to be driving full out on zandvoort in little over an hour and brake fade is the last thing on my mind ![]() (possible rain is on my mind though) Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
08-08-2007, 03:12 PM
Brake fading
Mux213 Wrote:Banpei, Limburg rules man!You can hardly call that touges. A touge is a narrow (mountain)pass and we don't have those in Holland. ![]() Edit: except the narrow streets of Giethoorn ofcourse. > ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
08-08-2007, 03:20 PM
Brake fading
banpei Wrote:You can hardly call that touges. A touge is a narrow (mountain)pass and we don't have those in Holland.Remind me to once give you the route we drove with the Delorean club around vaals. The road up and down to the 3 landen punt definately counts as a (small) touge but there are many more around there. But indeed, there is no "drive full down the road for 15 mins" touge in that respect. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
08-08-2007, 05:51 PM
Brake fading
It was indeed that road between epen and vaals.
It's only 5-3minutes one way, depends on how fast you are offcourse ![]() So you think that the pads are no good? I was thinking, since the pedal got so soft, maybe the brake fluid is getting too hot. But it's fresh dot4, like only 2 months old. ![]() What do you guys run on zandvoort, except the mintex pads? And how long do you drive there? Also, on the touge some parts only consist of short straights and sharp turns. So you use the brakes more often without them being cooled on the straights. PS. Jamie, reply my pm please!!! ![]() |
08-08-2007, 06:05 PM
Brake fading
Fluid fade = mushy pedal
Pad fade = Firm pedal, but not slowing down. Try grippy pads first..they bite better and need less time to slow the car down. Same amount of heat going into the system (same car, same speed = same amount of energy dissipated), but larger temp-gradient so more effective cooling. They're pretty cheap to, so try out a set of those mintexes while you wait for a possible RX7 swap. A wheel to steer the front of the car A pedal to steer the rear |
08-08-2007, 07:14 PM
Brake fading
I'm driving around with the mintexes M1144 for almost a year, they don't really fade that fast. But after a few laps on breaking before the tarzan they will get really hot and begin to fade a bit.
When i'm off the circuit the smoke comes out of the wheels ![]() But the serious upgrade is almost complete.. |
08-09-2007, 08:17 PM
Brake fading
I agree mintex is the first thing you should try out
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
Brake master cylinder for FC3S brake conversion | Hachi Go | 8 | 14,478 |
03-03-2011 12:06 AM Last Post: filh |
How to bleed brake system after master brake replacement | Ivan141 | 12 | 19,603 |
09-18-2005 11:21 PM Last Post: Ivan141 |
