Brake master cylinder
01-29-2007, 12:06 AM
Kouki master cylinder have 4 bolts and Zenki 2 bolts?
![]() ![]() Pic from eg6maxx project I'm looking for internet and only find 2 bolts master cylinder, Do you know where I can buy an OEM or aftermarket brake master cylinder? in toyota cost 200€ ![]() I can put a master cylider of other car and have mor power of brake? Regards ![]() |
01-29-2007, 10:02 AM
What if you took the booster can and the master cylindar out of a Zenki and used it that way?
01-29-2007, 10:17 AM
I put an SW20 MR2 Turbo master cylinder on my kouki AE86 - drops right in with no problem whatsoever. You can find brand new ones on eBay for less than 50 USD. The flud level sensor connector is different but it's easy to change.
Edit: for example, here. |
01-29-2007, 11:43 AM
Firehawk,
Thats an interesting mod! Does the SW20 booster also work better? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
01-29-2007, 12:04 PM
There is a guy on US ebay who sells OEM master cylinders at USD$59 or buy it now USD$65. I got one and it arrived in Australia in about 5 days. It has had the 'toyota' on the casting ground off so it's factory and brand spanking new.
It has the two hole attachment to the booster and these are at 180 degrees, i.e. horizontal. The front brake line comes out at 90 degrees from the end i.e. straight upwards rather than directly outward toward the front of the car. Simple to make up this small section of line. The brake warning loom connector is different from JDM but easy to swap over. |
01-29-2007, 12:54 PM
Mux213 Wrote:Thats an interesting mod!The booster is the stock AE86 one - only the MC is from SW20. The 90-91 SW20 MC is 7/8" in diameter, which is the same as the kouki AE86 one, but 92 onwards SW20 MC is 15/16" and should provide a firmer pedal feel over the original - especially when using non-standard brakes, such as the FC3S twin-pot ones. |
01-29-2007, 01:01 PM
i've heard that mitsubishi starion booster fits with no problems(dAYTONA told me
![]() that's an upgrade. Philip |
01-29-2007, 04:01 PM
searching sw20 master cylinder, than you very much!!!!!
Regards ![]() |
01-29-2007, 06:11 PM
Do you guys have any idea what an üpgrade"for your master cilinder is??
bigger is not always better! FABRICA MI DIEM, PVNC! |
01-29-2007, 07:43 PM
I was talking about the booster..
master cylinder is just distributing as far as I know Philip |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,400 |
Brake advice - master cylinder | mannix20vt | 12 | 14,856 |
Correct connection brake master cylinder? | bozu | 5 | 7,618 |
torque setting head cylinder bolts | izanagi | 1 | 5,127 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Dimensions clutch master cylinder | bozu | 2 | 6,398 |
04-16-2015 07:11 AM Last Post: bozu |
User(s) browsing this thread:
