Built like an A-10 (Thunderbolt II aka Warthog)
05-22-2011, 12:14 AM
This is HC work and it is going to break your balls how stiff it is...PERFECT detailing.
05-24-2011, 12:05 AM
Stiff, but smooth was the goal. Comes close.
New powerplant: Andrew |
05-24-2011, 12:11 AM
Nice!!
I am curious how you will build it in, when are you going to start? |
05-24-2011, 02:26 AM
I'll start posting it up here in the next couple days. Andrew |
05-26-2011, 08:11 AM
Stripped down.
New timing belt, waterpump, etc. Chromoly lightweight flywheel and illegal garage clutch. Modified bellhousing to fit a W58. Sold the 6 speed as I figured I'd probably break it. Shoe horned it in. ... required some oil pan clearancing. More to come. Andrew |
05-26-2011, 06:44 PM
Nice
SR Team BURN THE RUBER NOT YOUR SOUL! |
05-28-2011, 05:43 AM
The ECU - Vi-PEC V44 (Thanks to Bob @ Drift-Office)
Stock harness, removed, labeled & ready for destruction. Mounds of wiring spaghetti, everything to the left is trash and a bit of whats the right as well. Started making the harness. WTF was I thinking?!? Came out pretty good for the first harness/standalone I've ever made/installed. Andrew |
05-28-2011, 08:50 AM
nice work
toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
06-01-2011, 09:33 PM
Before I forget, HUGE thank you to Jonnie Fraz @ Stealth Custom Fab for making the engine/trans mounts AND doing a crazy amount of welding to put the exhaust together from downpipe back.
Started off with the stock header/manifold... and worked our way back from there. Filled her up, primed the oil pump with a TON of cranking. And got her started Sunday 4/17. Modified an old faded CF hood to fit, as my old dropvent came down right on the valve cover. Went and got tuning done Thursday 4/21. Thanks to (in some cases AGAIN): Jonnie Fraz @ http://stealth-custom-fab.com Larry @ BLS Bob @ Drift-Office in WA Shad @ http://www.drivingambition.us Andrew |
06-01-2011, 10:23 PM
congrats mate..what mods you need to fit beams inside?you put it alone?what about ecu etc?
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,356 |
ae86 Trueno f20c Built to be driven not polished | Martynas | 45 | 55,407 |
05-29-2020 12:59 PM Last Post: decryphe |
Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 43,032 |
07-22-2019 02:55 PM Last Post: apardal |
ae86 3sge beams turbo built v mount intercooler | boryae86 | 9 | 23,077 |
10-25-2010 02:46 PM Last Post: boryae86 |
