Built like an A-10 (Thunderbolt II aka Warthog)
05-22-2011, 12:14 AM
Huh This is HC work and it is going to break your balls Cool how stiff it is...PERFECT detailing.
05-24-2011, 12:05 AM
Stiff, but smooth was the goal. Comes close.
New powerplant:
[Image: AEU86 AE86 - Built like an A-10 (Thunder...a Warthog)]
Andrew
05-24-2011, 12:11 AM
Nice!! Thumbs up! Thumbs up!
I am curious how you will build it in, when are you going to start?
05-24-2011, 02:26 AM
... Wink
I'll start posting it up here in the next couple days.
Andrew
05-26-2011, 08:11 AM
Stripped down.
Smile
New timing belt, waterpump, etc.
Chromoly lightweight flywheel and illegal garage clutch.
Modified bellhousing to fit a W58. Sold the 6 speed as I figured I'd probably break it.
Shoe horned it in.
... required some oil pan clearancing.
More to come.
Andrew
05-26-2011, 06:44 PM
Nice Thumbs up!
SR Team
BURN THE RUBER NOT YOUR SOUL!
05-28-2011, 05:43 AM
The ECU - Vi-PEC V44 (Thanks to Bob @ Drift-Office)
Stock harness, removed, labeled & ready for destruction.
Mounds of wiring spaghetti, everything to the left is trash and a bit of whats the right as well.
Started making the harness.
WTF was I thinking?!?
Came out pretty good for the first harness/standalone I've ever made/installed.
Andrew
05-28-2011, 08:50 AM
nice work Thumbs up!
06-01-2011, 09:33 PM
Before I forget, HUGE thank you to Jonnie Fraz @ Stealth Custom Fab for making the engine/trans mounts AND doing a crazy amount of welding to put the exhaust together from downpipe back.
Started off with the stock header/manifold... and worked our way back from there.
Filled her up, primed the oil pump with a TON of cranking. And got her started Sunday 4/17.
Modified an old faded CF hood to fit, as my old dropvent came down right on the valve cover.
Went and got tuning done Thursday 4/21.
Thanks to (in some cases AGAIN):
Jonnie Fraz @ http://stealth-custom-fab.com
Larry @ BLS
Bob @ Drift-Office in WA
Shad @ http://www.drivingambition.us
Andrew
06-01-2011, 10:23 PM
congrats mate..what mods you need to fit beams inside?you put it alone?what about ecu etc?
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,373 10-28-2022 08:23 AM
Last Post: decryphe
  ae86 Trueno f20c Built to be driven not polished Martynas 45 55,785 05-29-2020 12:59 PM
Last Post: decryphe
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 43,488 07-22-2019 02:55 PM
Last Post: apardal
  ae86 3sge beams turbo built v mount intercooler boryae86 9 23,145 10-25-2010 02:46 PM
Last Post: boryae86
User(s) browsing this thread: 14 Guest(s)
