Cams doubt
02-01-2013, 12:33 AM
Cams doubt
T_AE86 Wrote:Thank you very much!! Above engine 112 to 115 @ the wheels Stock 4AGE hp measured @ the wheels... 100hp (+ or - 3hp) Crank horsepower numbers are stock 115, "prescription" engine above 130 Oh... to "save" horsepower... remove the engine powered fan, and fit an electric fan to the radiator... mechanical fan can steal 3-5hp Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-01-2013, 03:53 PM
Cams doubt
My other rebuilt engine I had with 81.5 pistons had 107 at the wheels...no camshafts just bigger pistons.
So I gained hp with bigger pistons... |
02-01-2013, 04:54 PM
Cams doubt
Be carefull comparing wheelhp outputs, there are so many variables between dyno's that the numbers can be off by as much as 10%, some are worse then that (e.g. when calling hub numbers hp@the wheels).
You would expect hp to scale at most with the increase in displacement. Going from 81 to 81.5 should yield about 1whp at most due to displacement. If its more then something else changed too. A wheel to steer the front of the car A pedal to steer the rear |
02-02-2013, 04:03 PM
Cams doubt
this has been posted here back in April 2009
robokill Wrote: Sticky this one lets make a large thread out of it. One point post if its WHP or HP ? most of the other things have been said already. AE86 ex-daily |
02-05-2013, 12:50 AM
Cams doubt
Thaks!!!
On the other hand, i was looking my removed engines, and i have a 3 rib (original of my zenki) and a 7 rib, i was reading a lot of info about their differences, but... I think you'll recomend to rebuild the 7rib, but what are the "feeling difference"? is faster, stronger, ...? Can i install a complete head from my zenki (3rib block) in a 7rib block?? (in toyodiy appears the same block in my two cars, and weren't the same) |
02-05-2013, 01:09 AM
Cams doubt
T_AE86 Wrote:Can i install a complete head from my zenki (3rib block) in a 7rib block?? (in toyodiy appears the same block in my two cars, and weren't the same) Any 4A/7A head on any 4A/7A block. |
02-05-2013, 08:56 AM
Cams doubt
you won't feel any difference between 3rib and 7rib you wont even be able to measure any difference. The only thing is that the 7rib will eventually last longer if put under stress... for most the 3rib will do just as well.
I personally went for the 7rib but not because of the ribs but due to the oilsquirters which in my application come in handy. AE86 ex-daily |
02-05-2013, 09:32 AM
Cams doubt
Got to ask, are there any diffrence on a Head from a 3 Rip and a 7 Rip, besides one is Bigported and the other is smallported?
My plan was to use a Bigported Head from a 3 Rip Block, and a 7 Rip Block with oilsquirters. Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
02-05-2013, 11:38 AM
Cams doubt
Vaptor Wrote:Got to ask, are there any diffrence on a Head from a 3 Rip and a 7 Rip, besides one is Bigported and the other is smallported? sheesh nobody reads anymore... as Uzelac said any 4a/7a head will fit any 4a/7a block ... so no there are no differences fitting wise... AE86 ex-daily |
02-05-2013, 12:06 PM
Cams doubt
Sorry.. Missed that line.
Shim size for AM cams | kazi | 4 | 5,188 |
Toda Cams | Alex170984 | 7 | 8,624 |
02-11-2017 05:50 PM Last Post: Alex170984 |
20V cams - CATCAMS vs KELFORD? | Grant | 19 | 38,815 |
11-19-2015 07:45 AM Last Post: hachirokkos |
cams cams cams | megabob | 60 | 56,836 |
12-31-2013 01:19 AM Last Post: gze spec |
part numbers on standard cams | Alex170984 | 10 | 10,789 |
09-19-2013 02:53 PM Last Post: pack |
