Can you add a blowoff to a supercharger?
07-13-2010, 08:36 PM
If so how can I do that in a 4AGZE running 0.6 bar boost?
Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-13-2010, 10:00 PM
With dual throttle bodies i guess...
07-14-2010, 07:45 AM
Recirculatory valves are very normal on positive displacement superchargers. Similar to recirculatory dumpvalves. Just attach one at the plenum and just before the supercharger.
07-28-2010, 02:36 AM
Is there anyone in the forum who added a blowoff to the Supercharged engine?
07-28-2010, 05:19 AM
You cannot use a blow off valve on a 4agze , well a stock one at least. In order for the blow off valve to be able to work , you need to relocate the tb to after the supercharger or basically just use the 4age intake manifold.
07-28-2010, 08:49 AM
Why do you want a blow off valve? For the pshhht sound? If so, then there some things you can buy that plug plumb into your exhaust that do the same thing.
If you want performance improvements then google for compressor bypass valve...Last thing I heard was that a 4A-GZE already hass one. A wheel to steer the front of the car A pedal to steer the rear |
07-29-2010, 02:32 AM
hehe.. yes shamefully i admit YES it IS for the blowoff sound... I just wanted to check if it can be done..
07-29-2010, 03:26 PM
heshan Wrote:hehe.. yes shamefully i admit YES it IS for the blowoff sound... I just wanted to check if it can be done.. It can be done as I have a dumpvalve on my engine currently. However, when i swoped my sc12 for a sc14 we took off alot of air hoses which connects to the bypass valve. We also made a new throttle with no additional air filter/cone filter/air box The sc14 have a lot less vacuum pipes then the sc12. My dumpvalve sits just after my FMIC before it leads to the throttle. I don't have a picture of the engine for you now Heshan but will put 1 on tomorrow. Current - 2006 Run X RSI TRD spec Current - 1991 AE92 Conquest 4AGTE Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM) Ex - 1983 1.8 SE Liftback(headworks and side draughts) |
08-09-2010, 01:00 AM
Hey Ash where's the pic buddy? Do you think I can do the same for the SC12??
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,136 |
03-05-2023 09:34 PM Last Post: Ivan141 |
Can you convert your 86 back too the original state? | gh0st | 7 | 2,700 |
04-25-2022 04:25 PM Last Post: gh0st |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 7,689 |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 10,284 |
09-08-2021 12:48 PM Last Post: Ryo |
can i just slam a oem turbo on it ? | MC_JP | 3 | 5,962 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
