Can you seperate trueno kouki bumper lights into zenki bumper lights?
11-26-2021, 04:03 PM
(11-14-2021 10:02 AM)GenkiMotors Wrote:  AW11 bumper lights will fit, but the mounting studs are in a different spot, but it is possible to relocate the studs as the housing is exactly the same. I couldnt find any here in Japan for under $300 USD when I was building my car so I used MR2 ones. Also the harness is a little different so you will need to crimp up some adapter wires.
Thanks everyone, I think I will buy some MR2 bumper lights then!
Just out of pure curiosity; are Trueno zenki bumper lights and Levin Zenki bumper lights the same and can the Levin zenki bumper lights fit in a Trueno zenki bumper?
11-26-2021, 08:48 PM
Not the same part number, and they are not the same physically either.
11-27-2021, 01:24 AM
Ah, ok. Thanks!
11-29-2021, 02:42 PM
The Levin bumper lights only have a single indicator light while the Trueno/MR2 has two bulbs with an indicator and parking light (stadslicht) next to each other.
[Image: AEU86 AE86 - Can you seperate trueno kou...er lights?]
12-14-2021, 11:21 PM
(10-08-2021 09:24 PM)banpei Wrote:  The kouki indicators are bigger (higher) than the zenki indicators, so they simply won't fit.
Like Pack says, the glass of the MR2 indicators is the same shape/size and fitting holes are also at the same spot. I replaced the glass of my JDM Trueno with the ones from the MR2 to make them legal in NL. So I'd think they should fit the bumper with the same mountings.
I was wondering, where can I find the glass of a jdm (dark) zenki trueno bumper light and can I place it on an MR2 bumper lighthousing?
If it works I would have an original JDM zenki trueno bumper light as pictured below:
On a side note, I found a picture which shows what a trueno would like with MR2 bumper lights:
12-15-2021, 10:02 AM
You could just use some taillight tinting paint I suppose. That's banpei's trueno by the way.
12-15-2021, 02:25 PM
(12-14-2021 11:21 PM)gh0st Wrote:  On a side note, I found a picture which shows what a trueno would like with MR2 bumper lights:
Those Converse shoes on the left are indeed the shoes I wear when working on cars. Wink
12-19-2021, 11:58 PM
I have found a picture which neatly shows the hight differences between the bumperlights:
  Kouki to Zenki Levin grill conversion? Mylesmck 6 2,650 02-08-2024 10:30 AM
Last Post: r.ave
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,319 03-05-2023 09:34 PM
  Bash bar for zenki trueno bumper gh0st 3 1,636 02-08-2023 10:50 PM
  Can you convert your 86 back too the original state? gh0st 7 3,253 04-25-2022 04:25 PM
Last Post: gh0st
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,857 09-08-2021 12:48 PM
Last Post: Ryo
