Car not igniting 20V Omex ECU
07-04-2010, 10:00 AM
Hi Jezza,
Any particular reason you chose the Omex ECU? And excuse my ignorance, but running a wasted spark set-up, does that mean it still fires on all 4 cilinders all the time (like it does standard I believe?) or only the cilinder that need to be sparked? I'm looking for a nice set-up for my BT, so many information for me to look through. |
07-04-2010, 12:56 PM
The original does NOT fire all 4 cilinders at the same time.. that's not the wisest thing to do. It fires one at a time. Wasted spark is firing 2 at a time, where one of the 2 sparks goes wasted.
07-04-2010, 01:02 PM
Oh ok, learned something again.
07-05-2010, 12:20 AM
I picked up a new coil pack today and that's resolved the problem.
To answer your question Aram, I chose the Omex as the previous owner of my 20V had been using the same setup and I trusted his judgement. Also, their tech support has been second to none when I've run into issues, the guys there really know their stuff, it's just unfortunate I ran into this problem at 6pm on a Friday when the Omex offices closed, but after sitting back and taking time to look at the big picture I managed to find the issues. One thing Omex have stressed to me before in the past is it's unlikely that ECU will be the thing at fault. I really thought that the issue I had faced here had spiked the ECU and it could have very well been dead but Omex are very sure of their product holding up under such situations. |
07-26-2010, 06:02 PM
Ok, thanks for the answer mate.
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,056 |
20v BT conversion ECU | izanagi | 5 | 6,814 |
06-14-2016 02:39 PM Last Post: izanagi |
20V blacktop. what kind off ecu??? | slowboy2 | 11 | 13,647 |
07-17-2015 07:01 PM Last Post: jdm86gtz |
16V ECU pinout on 20v swap | pack | 2 | 5,428 |
06-12-2015 01:22 AM Last Post: pack |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,067 |
09-15-2013 01:08 AM Last Post: jondee86 |
