Poll: Would you choose carbs (Weber, Dellorto, Mikuni...) instead of the stock EFI of the 4AG?
I'd choose carbs
I'd choose EFI
I'd choose ITB (independed throttle bodies, added later by MODSmile)
[Show Results]
Carbs for the 4AG
06-17-2005, 09:39 PM
Post: #41
Carbs for the 4AG
SutteR Wrote:Thanks! Since I don't know any place to make this sonics cleaning and I'm not sure if it will help gaining some performance out of my hachi I'll buy some fluid and clean the injectors myself.
After that I can swap to carbs... Tongue
Often cleaning services are combined with flow rating of injectors. That way you know are your injectors up to the task or not (leaning).
06-17-2005, 09:48 PM
Post: #42
Carbs for the 4AG
The ultrasound will 'vibrate' larger dirt particals that normally do not disolve or keep the fluid from reaching inside the injector and brake them up and loosen them from the surface they stick to. This way the injectors get really really clean.
I had my DeLorean injectors done with great success, unfortunally dirt in the fuel system has already taken its toll since then... 25 year old crap...Smile
06-17-2005, 10:00 PM
Post: #43
Carbs for the 4AG
mux213 Wrote:... 25 year old crap...Smile
LOL! Hurray!
I'll look after some injector cleaning service around.
  Question about 4AG 20v Engine Block CHACAMAN 1 1,760 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,546 02-10-2020 06:39 PM
Last Post: Power_uP
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,367 11-05-2016 01:34 AM
  SOME 4AG valve spring specs oldeskewltoy 5 13,631 05-04-2015 01:17 PM
Last Post: Project D
  tacho issues using haltech e6x on 4ag 20v bluehachi 5 7,285 06-05-2013 06:34 PM
Last Post: Rasteirinho
