Carbs for the 4AG
06-15-2005, 06:17 PM
Carbs for the 4AG
i am think also about to using carburetors,
i am not familiar with electronic and i can buy a cheap set of weber dcoes 45mm. but i think about this only if i make some power upgrades for the engine, for the stock one is the tvis with ecu better. the intake is the most problem. but i have seen an carb intake manifold on this forum ![]() i can make it on cnc milling machine but i have not the time to draw it. (and i have not an hachi ![]() about the ignition is it a good tip. and the fuel pump can you use from an lada ![]() an other way is to use the mikuni carb set from an motorcycle. http://www.86ers.org All the hachies that Daytona can only dream about. |
06-15-2005, 06:34 PM
Carbs for the 4AG
SekiguchiUeno Wrote:and the fuel pump can you use from an lada Lada is coool but it has a mechanical AC pump mounted on its block. How can it work on the 4A block? Btw...the hachi SR5 also have this kind of AC pump and then I think I will use genuine Toyota parts...
06-15-2005, 09:27 PM
Carbs for the 4AG
its was an joke:O)
i know that hungarians like ladas and tune em up. but i have don`t any know how about lada`s i would like to meet you an see your work on the hachi. i can translate your hungarian 86 sites, and manuals for the ignition but i must find time for it. http://www.86ers.org All the hachies that Daytona can only dream about. |
06-15-2005, 09:43 PM
Carbs for the 4AG
Hey, u speak Hungarian??? That's great, and very rare!
OFF: About Ladas: http://www.zsiguli.hu - a great site of a circle of friends (of mine) (also has english version) ON My hachi is not so much fun till now, meet sometime later... |
06-16-2005, 11:08 AM
Carbs for the 4AG
2 SekiguchiUeno:
Quote:I can make it on cnc milling machine but i have not the time to draw it. I already have the Autocad drawing - my problem here is CNC milling (very bad services). |
06-16-2005, 11:27 AM
Carbs for the 4AG
jamiemirror Wrote:2 SekiguchiUeno: What kind of carbs have you the drawing for? Weber, Dellorto, what? |
06-16-2005, 11:32 AM
Carbs for the 4AG
40s.
Sutter, Weber, Delorto and Solex sidedraughts share the same pattern to intake adapter - so this is universal. PS: the drawing is made for bigport head (bluetop). I can made one for smallport also. |
06-16-2005, 11:38 AM
Carbs for the 4AG
jamiemirror Wrote:40s. Sorry, didn't know. I have bigport... :wink: Starting to look after CNC around here. |
06-16-2005, 11:47 AM
Carbs for the 4AG
Sutter, no need to look for CNC - I already prepared production, waiting unconfirmed request from a club member ( :-)) ) to fulfill my 5-piece quota.
The problems with CNC: 1. You must enter manually (!!!) whole drawing (no Autocad import !!!). 2. You must produce as much adapters as you can at once (to lower the costs - the main cost is CNC programming, see 1.). |
06-16-2005, 12:21 PM
Carbs for the 4AG
Oh, I understand. Is there any other way than CNC? Something manual... I don't know how the intakes e.g for the ladas are made here but that have to be a low cost something...
I'll ask a few people about it. Btw. about how much would the intake cost if only 5 pieces are made? I might be able to find someone who also wants this mod. |
| Question about 4AG 20v Engine Block | CHACAMAN | 1 | 2,643 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 15,282 |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 6,461 |
| SOME 4AG valve spring specs | oldeskewltoy | 5 | 15,168 |
05-04-2015 01:17 PM Last Post: Project D |
| tacho issues using haltech e6x on 4ag 20v | bluehachi | 5 | 8,663 |
06-05-2013 06:34 PM Last Post: Rasteirinho |
