Poll: Would you choose carbs (Weber, Dellorto, Mikuni...) instead of the stock EFI of the 4AG?
I'd choose carbs
I'd choose EFI
I'd choose ITB (independed throttle bodies, added later by MODSmile)
[Show Results]
Carbs for the 4AG
06-15-2005, 06:17 PM
Carbs for the 4AG
i am think also about to using carburetors,
i am not familiar with electronic and i can buy a cheap set of weber dcoes 45mm.
but i think about this only if i make some power upgrades for the engine, for the stock one is the tvis with ecu better.
the intake is the most problem.
but i have seen an carb intake manifold on this forumSmile
i can make it on cnc milling machine but i have not the time to draw it.
(and i have not an hachiSmile
about the ignition is it a good tip.
and the fuel pump can you use from an ladaSmile
an other way is to use the mikuni carb set from an motorcycle.
http://www.86ers.org
06-15-2005, 06:34 PM
Carbs for the 4AG
SekiguchiUeno Wrote:and the fuel pump can you use from an ladaSmile
Lada is coool but it has a mechanical AC pump mounted on its block. How can it work on the 4A block?
Btw...the hachi SR5 also have this kind of AC pump and then I think I will use genuine Toyota parts... Smile
06-15-2005, 09:27 PM
Carbs for the 4AG
its was an joke:O)
i know that hungarians like ladas and tune em up.
but i have don`t any know how about lada`s Sad
i would like to meet you an see your work on the hachi.
i can translate your hungarian 86 sites, and manuals for the ignition but i must find time for it.
06-15-2005, 09:43 PM
Carbs for the 4AG
Hey, u speak Hungarian??? That's great, and very rare! Smile Respect!
OFF:
About Ladas: http://www.zsiguli.hu - a great site of a circle of friends (of mine) (also has english version)
ON
My hachi is not so much fun till now, meet sometime later... Undecided
06-16-2005, 11:08 AM
Carbs for the 4AG
2 SekiguchiUeno:
Quote:I can make it on cnc milling machine but i have not the time to draw it.
I already have the Autocad drawing - my problem here is CNC milling (very bad services).
06-16-2005, 11:27 AM
Carbs for the 4AG
jamiemirror Wrote:2 SekiguchiUeno:
What kind of carbs have you the drawing for? Weber, Dellorto, what?
06-16-2005, 11:32 AM
Carbs for the 4AG
40s.
Sutter, Weber, Delorto and Solex sidedraughts share the same pattern to intake adapter - so this is universal.
PS: the drawing is made for bigport head (bluetop). I can made one for smallport also.
06-16-2005, 11:38 AM
Carbs for the 4AG
jamiemirror Wrote:40s.
Sorry, didn't know. Respect!
I have bigport... :wink: Starting to look after CNC around here.
06-16-2005, 11:47 AM
Carbs for the 4AG
Sutter, no need to look for CNC - I already prepared production, waiting unconfirmed request from a club member ( :-)) ) to fulfill my 5-piece quota.
The problems with CNC:
1. You must enter manually (!!!) whole drawing (no Autocad import !!!).
2. You must produce as much adapters as you can at once (to lower the costs - the main cost is CNC programming, see 1.).
06-16-2005, 12:21 PM
Carbs for the 4AG
Oh, I understand. Is there any other way than CNC? Something manual... I don't know how the intakes e.g for the ladas are made here but that have to be a low cost something...
I'll ask a few people about it.
Btw. about how much would the intake cost if only 5 pieces are made? I might be able to find someone who also wants this mod.
  Question about 4AG 20v Engine Block CHACAMAN 1 1,758 06-10-2022 05:17 PM
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,544 02-10-2020 06:39 PM
Last Post: Power_uP
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,367 11-05-2016 01:34 AM
  SOME 4AG valve spring specs oldeskewltoy 5 13,631 05-04-2015 01:17 PM
Last Post: Project D
  tacho issues using haltech e6x on 4ag 20v bluehachi 5 7,283 06-05-2013 06:34 PM
Last Post: Rasteirinho
