Carbs for the 4AG
06-16-2005, 03:15 PM
Carbs for the 4AG
Another thing what can be critical when modding to carbs: will we able to get somewhere some vacuum for the brake servo?
06-16-2005, 04:17 PM
Carbs for the 4AG
Up to 5 - price will be up to 150 EU each (aluminium billet).
Lada's are easy - Toyota uses oval shape of intake ports insteal of circle - in Lada. Already have 2 requested, 1 "interested" and pending 2 others (waiting to confirm request). More=lower price. When you remove original intake manifold, you can use injector holes in the head as vacuum source (using vacuum tank will help) :-) And there is no way to build this adapter billet in hand - it is not simple ! You can try with flanges and tubes - but it's not simple job. PS: FYI Lada mild steel intake (welded) + pair of 40's DelOrtos can be found even for 100 EU here - matter of luck. Very simple intake... |
06-16-2005, 04:29 PM
Carbs for the 4AG
Whoooaahhh... 150EUR, that's not cheap! I have to re-estimate this project...
![]() That vacuum thing is strange,I don't know the heads inside...is it really that easy? And the another holes have to be closed some way? |
06-16-2005, 04:35 PM
Carbs for the 4AG
SutteR Wrote:Whoooaahhh... 150EUR, that's not cheap! I have to re-estimate this project... There is no way to fall under 120EU even I cross the 10 adapters "border", the 35mm aluminium plates (material) are not cheap too. There is no another holes to be shut. Just injector holes. |
06-16-2005, 04:39 PM
Carbs for the 4AG
Bad news... OK, I've known that project won't be cheap so no problem I wrtie this cost to my list. When it is ready I sit down and calculate some total. If it is affordable then I start if not then not.
06-16-2005, 04:42 PM
Carbs for the 4AG
SutteR Wrote:Bad news... OK, I've known that project won't be cheap so no problem I wrtie this cost to my list. When it is ready I sit down and calculate some total. If it is affordable then I start if not then not.If you want very low-priced solution - you must use flanges and short tubes (steel) and weld the intake adapter. This will work but I tried to avoid it instead of billet aluminium. |
06-16-2005, 04:49 PM
Carbs for the 4AG
I'd have to know both prices. The alu intake adapter can't be wrong. I write that on my list as I've said. :wink:
06-17-2005, 11:27 AM
Carbs for the 4AG
After 3 days the poll shows that there are twice as much who want to use the stock EFI as who voted for carbs.
Strange. I've known that the carbs aren't everyones dream, but I counted upon a ratio of 50:50. Anyways...12 votes aren't a significant pattern IMHO. |
06-17-2005, 11:32 AM
Carbs for the 4AG
SutteR Wrote:After 3 days the poll shows that there are twice as much who want to use the stock EFI as who voted for carbs. Try votes for ITB (injected) - and compare results. |
06-17-2005, 11:39 AM
Carbs for the 4AG
Added the itb option
![]() I must say I will stick with EFI purely for cost issues but both ITB and Carbs seem a sweet choice to me. In the end though I think ITBs would have my choice. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,756 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,542 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,365 |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,630 |
05-04-2015 01:17 PM Last Post: Project D |
tacho issues using haltech e6x on 4ag 20v | bluehachi | 5 | 7,274 |
06-05-2013 06:34 PM Last Post: Rasteirinho |
