Carbs: would this work ?
06-07-2008, 07:47 PM
Twin 45DCOE carbs + standard ecu with vacuum setup for MAP sensor and TPS sensor fitted to carbs.
Could I use the injectors as well so the carbs act like throttle bodies.... or is there something blindingly obvious I have overlooked ? An analogue brain in a digital World |
06-07-2008, 08:26 PM
I have seen an engine go boom that way. Reading was incorrect and the engine revved over 9000. Wouldn't do it like that. Just get some itb's from a 20v
06-07-2008, 10:50 PM
I did It like that and I recommend it, I just removed the insides of the carbs and blocked all the holes, adapted the tps, and built a vacuum tank, But like all itb's, it didn't work good on stock ecu.
![]() 280z '75 audi S4 B5 '99 KE25 '71 |
06-07-2008, 11:22 PM
How did you adapt the TPS ?
06-08-2008, 12:23 PM
Just an idea .. for a inlet plenum so you can take an equalised reading across all 4 runners - why not use a spare fuel rail. Almost perfectly suited for this. 5 holes already there and just seal off the 1 remaining one. Neat and compact, and has spare bolt joles to fit it to the block.
![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
06-08-2008, 02:56 PM
eight-six Wrote:Just an idea .. for a inlet plenum so you can take an equalised reading across all 4 runners - why not use a spare fuel rail. Almost perfectly suited for this. 5 holes already there and just seal off the 1 remaining one. Neat and compact, and has spare bolt joles to fit it to the block.Ha ha, just came in from the garage with exactly the same idea !! Is yours running ok now ? An analogue brain in a digital World |
06-08-2008, 09:38 PM
Hi Mate, yes it is .. finally, came down to either a faulty igniter or the O2 sensor pulling the timing.
Using the carbs as throttle bodies is a very good idea, you just need to make sure that you wont get any vacuum leaks past the carb throttle plates. Map will be easy to set up, TPS will be trickier - also depends on the linkage set up you have on your Webers? Are the carbs fully working? I can detail what I have done to get mine working off the stock ECU. ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
06-08-2008, 10:42 PM
"Map will be easy to set up, TPS will be trickier - also depends on the linkage set up you have on your Webers?
Are the carbs fully working? I can detail what I have done to get mine working off the stock ECU." can you be more detailed with these ? AE86 FANATIC!!! |
06-13-2008, 08:22 PM
That looks super impressive good work.
How seatbelt rails work? | FanIsHere | 2 | 4,710 |
05-18-2016 09:52 AM Last Post: Bean |
How would/have you rebuild your 4age? | joaotcgt | 6 | 9,095 |
07-21-2015 10:40 AM Last Post: mad.matt |
my last work , Dentist needed | filh | 5 | 6,042 |
03-29-2013 07:47 AM Last Post: assassin10000 |
Type of carbs to suit 4ag | kpretro84 | 23 | 24,607 |
02-09-2013 02:29 AM Last Post: bakonick |
TPS for carbs | totta Crolla | 7 | 7,617 |
01-30-2013 09:14 PM Last Post: totta Crolla |
