my last work , Dentist needed
03-28-2013, 11:54 AM
I need a dentist............
Just after 500m , into a rally stage , no noises before , and suddently,
a big CRACK , and i stopped .
No more move possible .
It'(s) was a TRD gearbox , , now a silent one .
I guess it's impossible to get parts to repair
The 4th gear pinions are both dead , but I think that the one on input shaft can't be changed (remaing stock on TRD gear set)
But It can be removed from input shaft.
I can use a stock one from the output shaft.
Any advices welcomed .
Defenatly too hard to drive with a stock gear box (4,7:1 gear end).
Always between 1st and 2nd gear in 90° corners.
regards
Phil
Filh
Save the RWD cars
03-28-2013, 02:00 PM
Does your rally class allow a gearbox conversion? I think a Ford gearbox would be much easier to maintain and find replacement parts for.
03-29-2013, 12:09 AM
Thanks Ivan
If I can't find a reasonable offer , I'll probably go for that.
Regards
Phil
Filh
Save the RWD cars
03-29-2013, 01:27 AM
it is the drop gear that is broken 4 th are 1:1 and involve any gears
03-29-2013, 07:47 AM
^ as he said.
That's your input shaft to countershaft gears that are stripped. 1,2,3,5 & R. 4th locks input and output together and should still work.
New gear set or new transmission.
Andrew
  How seatbelt rails work? FanIsHere 2 5,776 05-18-2016 09:52 AM
  How does the 4age AFM system work? heshan 22 29,149 12-20-2012 05:01 AM
Last Post: heshan
  my tvis doesnt work... daywalker 30 54,607 02-19-2012 01:25 PM
Last Post: ZDoman
  few issues after last drift days, advice needed fax0815 3 5,680 08-26-2011 08:33 AM
Last Post: jondee86
  Work equip 01 max offset?? stalker 5 10,713 08-23-2011 03:09 AM
Last Post: Lewy
