Caster settings
09-16-2007, 10:29 PM
Caster settings
Is it possible to adjust the caster settings with a stock suspension?
[Image: AEU86 AE86 - Caster settings]
09-17-2007, 01:03 AM
Caster settings
of course. its those two huge bolts on the strut bar / upper arm (the thin round one). torque for these two bolts is 925 kg-cm
The original specs are 3°40' left and right, and the error between sides can be 30'.
I wonder what kind of setting have you ppl tried ? I have a feeling that steering is quite heavy with the stock specifications..
09-17-2007, 01:58 PM
Caster settings
Thanks mate! Thumbs up!
It's more because my left wheel still touches the panel behind the wheel with full lock. Right doesnt, so I think there is a little error between them.
  Torque settings kazi 4 9,391 03-28-2017 12:15 AM
Last Post: kazi
  What is normal and low caster in Cusco camber plates?? T_AE86 9 17,452 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Settings for HKS 256 cams on stock engine Bean 7 9,568 03-16-2008 10:56 AM
  How to improove oem WHEEL ALIGNMENT settings (toe&caster Apolan 13 15,792 03-12-2008 02:58 PM
Last Post: Roku_trueno
  cam duration and installation settings alimonos 6 7,201 12-05-2006 12:47 PM
Last Post: NoHachi
