Caster settings
09-16-2007, 10:29 PM
Caster settings
Is it possible to adjust the caster settings with a stock suspension?
09-17-2007, 01:03 AM
Caster settings
of course. its those two huge bolts on the strut bar / upper arm (the thin round one). torque for these two bolts is 925 kg-cm
The original specs are 3°40' left and right, and the error between sides can be 30'. I wonder what kind of setting have you ppl tried ? I have a feeling that steering is quite heavy with the stock specifications.. |
09-17-2007, 01:58 PM
Caster settings
Thanks mate!
![]() It's more because my left wheel still touches the panel behind the wheel with full lock. Right doesnt, so I think there is a little error between them. 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
Torque settings | kazi | 4 | 7,270 |
03-28-2017 12:15 AM Last Post: kazi |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 15,414 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Settings for HKS 256 cams on stock engine | Bean | 7 | 8,299 |
03-16-2008 10:56 AM Last Post: Bean |
How to improove oem WHEEL ALIGNMENT settings (toe&caster | Apolan | 13 | 13,139 |
03-12-2008 02:58 PM Last Post: Roku_trueno |
cam duration and installation settings | alimonos | 6 | 5,985 |
12-05-2006 12:47 PM Last Post: NoHachi |
