Catalytic converter replacement
06-06-2015, 04:30 PM
Hello
I am looking to replace my old Catalytic converter on my AE86.
For OEM i was not able to find exact part number and i bet it will not be cheap.
I found somewhere mentioned that Magnaflow 23886 will be a good replacement but i am unable to locate a store in Europe where i can get it.
Prices for importing stuff to my country always double the price so it is really trouble to get import stuff outside EU.
Also as my rear exhaust gone i am looking for replacement. Anyone know if 17430-16052 part from toyota can be still available and which price i can expect. Was looking other manufacturers but everything new cost a lot and most of exhausts are loud. Not sure if i can get HKS Sport or Fujitsubo legalis R in europe but i bet not.
I found O2 sensor is available from NTK so at least this don't seem the issue to replace.
I need to pass MOT in a month with this old lady so need to fix that exhaust.
The emissions last time have been pretty high. Lucky that they let the car pass as non CAT but they will not do this exception forever i am afraid Sad This country starts to follow this bastards in EU regulations as well.
85' AE86 GT coupe lifetime project since 2005
06-06-2015, 09:17 PM
where are you located and what's your budget? this will help us make a better recommendation. also is you engine stock or modified?
06-08-2015, 08:43 AM
Brick Catalytic converter replacement
There is a lot of BS talked about performance exhausts. Having a shiny
stainless steel fart canon sticking out the back of your car is only good
for annoying your neighbours Tongue Any half-decent exhaust shop should be
able to make you up an exhaust system by cutting and welding standard
components.
For stock or near stock engine use 2" tube with a triple-pass "turbo-flow"
type silencer at the back, an 18" glass-pack "hot-dog" type resonator
under the floor, and a hi-flow aftermarket cat. Make it go over the rear
axle... none of this lazy ass under diff crap Angry
Cheers... jondee86
06-10-2015, 08:44 PM
Hello
Car is stock AE86 gt coupe 2 door. Blue top AFM 85kw version. Location Slovakia Europe. My budget will be around 350e (approx price for the part 17430-16052 (original toyota exhaust)) so this is the price that will be ok for me i think. When looking at HKS sport catback or Fujitsubo Legalis R they will cost in my country imported taxed around 800e. This is too much for me.
06-10-2015, 09:29 PM (This post was last modified: 06-11-2015 05:53 PM by Deuce Cam.)
Magnaflow seems to have a bunch of different options available in the US, but I've never tried one. The federal version is reasonably priced around $146 USD, and available in the stock 2" pipe size. Shown here: http://www.magnaflow.com/02catalytic_con...tfit=23886
However, as jondee86 mentioned, any competent muffler shop (if available) should be able to help you out.
Edit: Looks like jegs.com offers international shipping.
06-10-2015, 09:38 PM
Wigth regards to O2 sensor how about this?
http://www.aliexpress.com/item/free-ship...17885.html
My car even older than I.
Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD
Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD
  Exhaust replacement banpei 35 6,361 10-24-2024 10:45 AM
Last Post: decryphe
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 6,150 11-05-2021 08:17 PM
Last Post: gh0st
  Coilover shock replacement phill 92 9 12,080 08-28-2012 08:46 PM
Last Post: phill 92
  replacement parts??? diff. slowboy2 5 5,961 02-03-2011 09:01 PM
Last Post: slowboy2
  Head Gasket Replacement - Block Surface Question ?? juantonwan 4 5,792 06-11-2009 02:24 PM
Last Post: ZDoman
