(Catching up) OST-086 MM: Built for Mario
10-17-2022, 07:46 PM
So... way back around OST-070, I was asked if I could reserve OST-086 for Mario.... Mario is our local (greater Portland, Oregon) AE86 reclaimer.... He has pieced together AE86s for the last 5-10 years reclaiming at least 10 from wrecks, and abandoned cars. His personal AE86 is a true rhd Levin coupe that he rebuilt from a damaged chassis. So when he asked, I kind of felt obliged.... He brought over his core... (note the TVIS effect on intake valves 1,4,5, and not so much but also on 8 ) His build specs were to keep the stock bottom end (9.4:1), so this build was to maximize the heads efficiency. First steps... get it cleaned, tumbled, and deburr the casting. Upon inspection this head had less then ideal machining from Toyota. Chambers 4, 3, and 2 have residual metal "hanging out" inside the combustion chamber.... shrouding intake valves 3, 5, and 7. 2 down... intake short radius is tidy, exhaust ports opened, and the first of the nasty chambers(chamber 2) is now cleared of the shrouding 4 down, valve job finished, just waiting for assembly Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-18-2022, 10:12 PM
I guess someone in the Tahara plant didn't have their morning brew yet. But indeed, that's quite a bad job this person did!
10-28-2022, 08:23 AM
I love watching these threads!
Also, those louvers on the Levin... I'm turning gelatinous. |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,246 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,011 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,922 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,522 |
(Catching up...) OST-081: STOP... do not touch if you don't know wtf you are doing | oldeskewltoy | 0 | 1,463 |
06-17-2022 09:07 PM Last Post: oldeskewltoy |
