(Catching up) OST-086 MM: Built for Mario
10-17-2022, 07:46 PM
![]() So... way back around OST-070, I was asked if I could reserve OST-086 for Mario.... Mario is our local (greater Portland, Oregon) AE86 reclaimer.... He has pieced together AE86s for the last 5-10 years reclaiming at least 10 from wrecks, and abandoned cars. His personal AE86 is a true rhd Levin coupe that he rebuilt from a damaged chassis. ![]() So when he asked, I kind of felt obliged.... ![]() He brought over his core... (note the TVIS effect on intake valves 1,4,5, and not so much but also on 8 ) ![]() His build specs were to keep the stock bottom end (9.4:1), so this build was to maximize the heads efficiency. First steps... get it cleaned, tumbled, and deburr the casting. ![]() Upon inspection this head had less then ideal machining from Toyota. Chambers 4, 3, and 2 have residual metal "hanging out" inside the combustion chamber.... shrouding intake valves 3, 5, and 7. ![]() 2 down... intake short radius is tidy, exhaust ports opened, and the first of the nasty chambers(chamber 2) is now cleared of the shrouding ![]() 4 down, valve job finished, just waiting for assembly
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-18-2022, 10:12 PM
I guess someone in the Tahara plant didn't have their morning brew yet. But indeed, that's quite a bad job this person did!
10-28-2022, 08:23 AM
I love watching these threads!
Also, those louvers on the Levin... I'm turning gelatinous. |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,440 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,045 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,294 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,674 |
| (Catching up...) OST-081: STOP... do not touch if you don't know wtf you are doing | oldeskewltoy | 0 | 2,346 |
06-17-2022 09:07 PM Last Post: oldeskewltoy |
![AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario [Image: AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario]](https://gallery.ostportworks.com/albums/userpics/10005/OST-086.jpg)
![AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario [Image: AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario]](https://gallery.ostportworks.com/albums/userpics/10005/marios_car_2_panel.jpg)
![AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario [Image: AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario]](https://gallery.ostportworks.com/albums/userpics/10005/disassembled~1.jpg)
![AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario [Image: AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario]](https://gallery.ostportworks.com/albums/userpics/10005/cam_side_-_shallow_angle.jpg)
![AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario [Image: AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario]](https://gallery.ostportworks.com/albums/userpics/10005/poor_original_machining.jpg)
![AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario [Image: AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario]](https://gallery.ostportworks.com/albums/userpics/10005/2_down_-_exhaust_and_chamber_view.jpg)
![AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario [Image: AEU86 AE86 - (Catching up) OST-086 MM: Built for Mario]](https://www.aeu86.org/sticker-banner-468.gif)
