Changing Mileometer reading?
04-13-2005, 12:20 PM
ahahaha yeah i suppose it is illegal! rofl.... i will still post pictures of the gauge cluster conversion if anyone is interested..?
Trueno for sale! |
04-13-2005, 12:43 PM
I would think if you reset the guage to the same milage as was shown in the documentation for the car when it's imported that's ok. I have also seen imports being sold with the reading converted from KM's to Miles and updated to reflect this so it must be OK.
04-17-2005, 10:19 PM
Well i changed the reading today...
I took apart the speedo...used the "fork" trick to take off the needle (Thanks Knudsen!!) Took the 2 screws from the speedo face off...and then i was stuck for what to do next. I ended up not actually disassembling the "roll" of numbers...I just kinda used a bit of force to change the numbers by hand. Seemed fine as far as I know. Then I just reassembled it. The longest part was actually getting the needle back on correctly..aha Hopefully I haven't screwed it up! Gauge change coming in the next 2 weeks or so! ![]() Trueno for sale! |
Changing distributor when carb 4age | izanagi | 14 | 16,166 |
Changing propshaft bearing. Anything I need to know? | Lauren | 5 | 9,052 |
04-15-2012 02:12 AM Last Post: krullibull |
changing diff ratio, broken LSD??? | fax0815 | 6 | 7,986 |
09-06-2011 08:19 PM Last Post: fax0815 |
changing from electric moter windows to winders big job? | irish ae86 | 5 | 6,740 |
03-31-2011 08:39 PM Last Post: Dogger |
vacuum reading on idle | Bean | 6 | 8,320 |
10-12-2010 11:28 AM Last Post: Bean |
User(s) browsing this thread:
