Changing Mileometer reading?
04-13-2005, 12:20 PM
ahahaha yeah i suppose it is illegal! rofl.... i will still post pictures of the gauge cluster conversion if anyone is interested..?
Trueno for sale!
04-13-2005, 12:43 PM
I would think if you reset the guage to the same milage as was shown in the documentation for the car when it's imported that's ok. I have also seen imports being sold with the reading converted from KM's to Miles and updated to reflect this so it must be OK.
[Image: AEU86 AE86 - Changing Mileometer reading?]
04-17-2005, 10:19 PM
Well i changed the reading today...
I took apart the speedo...used the "fork" trick to take off the needle (Thanks Knudsen!!)
Took the 2 screws from the speedo face off...and then i was stuck for what to do next. I ended up not actually disassembling the "roll" of numbers...I just kinda used a bit of force to change the numbers by hand. Seemed fine as far as I know. Then I just reassembled it. The longest part was actually getting the needle back on correctly..aha
Hopefully I haven't screwed it up! Gauge change coming in the next 2 weeks or so! Undecided
Trueno for sale!
  Changing distributor when carb 4age izanagi 14 16,112 07-04-2016 03:27 PM
Last Post: Uzelac
  Changing propshaft bearing. Anything I need to know? Lauren 5 9,010 04-15-2012 02:12 AM
Last Post: krullibull
  changing diff ratio, broken LSD??? fax0815 6 7,944 09-06-2011 08:19 PM
Last Post: fax0815
  changing from electric moter windows to winders big job? irish ae86 5 6,726 03-31-2011 08:39 PM
Last Post: Dogger
  vacuum reading on idle Bean 6 8,273 10-12-2010 11:28 AM
