Changing distributor when carb 4age
06-30-2016, 02:06 PM
Hi all,
Someone could explain me why the stock distributor would not works when carbing 4age ? I don't really find the answer on the net Thanks |
06-30-2016, 02:27 PM
It should work if you retain the ECU.. I suspect many people ditch the ECU alltogether.
06-30-2016, 02:51 PM
It is dependand on ECu, all the signals it gathers are interpreted by ECU who decides on timing.
Genuine 4AGE dizzy cant work on its own. But, any other standard distributor which has complete ignition logic, just need to change gear and plug it into head. You will need to change igniter and maybe coil. |
06-30-2016, 06:34 PM
How the ECU interacts with distributor ?
06-30-2016, 07:12 PM
(06-30-2016 06:34 PM)izanagi Wrote: How the ECU interacts with distributor ? In simple terms: The ECU will use sensor input (MAP/AFM, CAS, etc...) and set timing according to it's internal map and adjusters for other factors. AE86 ex-daily |
06-30-2016, 09:17 PM
(06-30-2016 07:12 PM)Bean Wrote:Does the ECU change the ignition timing or the injector timing ?(06-30-2016 06:34 PM)izanagi Wrote: How the ECU interacts with distributor ? |
06-30-2016, 09:19 PM
both - in your case there wouldn't be any injectors to drive.
AE86 ex-daily |
06-30-2016, 10:03 PM
Changing distributor when carb 4age | |||
07-01-2016, 12:19 PM
can you elaborate your question a bit more? I don't understand what you're asking.
AE86 ex-daily |
07-01-2016, 01:44 PM
Izanagi, I guess you are determined to make stock distributor work. You can't, not without some extra electronics wthich will either use additional pickup (crank/camshaft) or the one in stock distributor. Both ways demand serious fabrication.
It is easier to either buy specific ignition solution or adapt other distrubutor. |
Carb question please help | MIGGZFSU | 3 | 4,644 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
16v distributor hole plug | harkes | 8 | 9,435 |
Carb conversion but what is this and how ? | Allexz | 5 | 8,392 |
05-24-2016 08:48 AM Last Post: Allexz |
Distributor position and cranking | pack | 13 | 19,172 |
07-01-2013 11:08 PM Last Post: pack |
Mikuni carb help just wont balance | megabob | 3 | 5,103 |
01-01-2013 10:32 PM Last Post: allencr |
