Changing of connection rod bearings
05-06-2005, 11:58 AM
Heres the bearings from cylinder 1. No damage to the crank, only some of the soft material from the bearing is "burned" onto the crank. It could easily be removed with a razorblade...
05-06-2005, 02:16 PM
I would advise against using a razorblade...use some solvent and a soft brush..As long as there are no scratches on the crank you can put in new bearings..
  Question on Rod Bearings mister86 3 4,315 03-19-2020 03:46 AM
  Emergency help find store with bearings france Allexz 5 5,109 09-12-2019 03:24 PM
Last Post: Allexz
  Changing distributor when carb 4age izanagi 14 16,344 07-04-2016 03:27 PM
Last Post: Uzelac
  Correct connection brake master cylinder? bozu 5 7,623 07-26-2015 12:28 PM
Last Post: bozu
  Diff bearings izanagi 11 16,675 07-05-2014 07:29 PM
Last Post: assassin10000
