Changing of connection rod bearings
05-06-2005, 11:58 AM
Heres the bearings from cylinder 1. No damage to the crank, only some of the soft material from the bearing is "burned" onto the crank. It could easily be removed with a razorblade...
05-06-2005, 02:16 PM
I would advise against using a razorblade...use some solvent and a soft brush..As long as there are no scratches on the crank you can put in new bearings..
Question on Rod Bearings | mister86 | 3 | 3,858 |
03-19-2020 03:46 AM Last Post: oldeskewltoy |
Emergency help find store with bearings france | Allexz | 5 | 4,503 |
09-12-2019 03:24 PM Last Post: Allexz |
Changing distributor when carb 4age | izanagi | 14 | 14,929 |
Correct connection brake master cylinder? | bozu | 5 | 7,085 |
Diff bearings | izanagi | 11 | 15,560 |
07-05-2014 07:29 PM Last Post: assassin10000 |
