Click in steering column?
07-16-2023, 01:58 PM
Anyone know where this sound is coming from? I already opened the hub cap to check if the wheel bearing nut is tight enough. When I move the wheel center like on the video you hear a click first. It's quite enjoying when driving non tarmac streets. I thought about the steering rack, but when I move the steering wheel there is some free play, but the click doesn't come up, so it happens only when movement is coming from the wheel. Any suggestions?
https://youtu.be/IcjNLS-qTXA
[Image: AEU86 AE86 - Click in steering column?]
07-16-2023, 05:10 PM
Look at your balljoints while your doing this..you should be able to spot any movement in them. If its moving near the rack your inner ball joint might be worn.
To rule out your wheel bearings, grab your wheel at the 12 and 6 o clock positions and repeat the test. If it's clicking in that direction it's the bearings that are gone.
07-17-2023, 08:26 PM
Maybe try it without the wheel on.
  How to replace the steering column UJ? Mylesmck 4 2,288 05-14-2022 07:40 PM
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,028 07-31-2019 11:28 AM
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 44,213 10-02-2014 06:07 PM
  Steering column weight savings? 4000GT 4 5,559 09-20-2012 08:40 PM
Last Post: 4000GT
  Adjustable steering column 4000GT 6 8,667 07-12-2012 08:15 AM
Last Post: 4000GT
