Clunking noise coming from the rear axle
10-09-2008, 10:21 PM
Hi mates,
Today i finished the install of my new final gear ratio (4.77) because the old one (also 4.77) was improperly tuned and so it was whining/squealing very hard above 60 km/h. I went for a small test-drive with the new FGR and i couldn't hear any noises... until i started braking to stop on the traffic lights (engine at idle speed), when i started hearing a clunking noise coming from the rear axle. It's a sort of noise that increases/decreases its rythm with vehicle speed, it happens also when running straight and i can only hear it when driving forward. The oil level is correct. There's nothing loosened in the back (like a brake fluid pipe or handbrake cable). Already loosened the bolts that fix the center mount of the driveshaft so it can get freely to its desired position. My suspicions goes to the half shafts, maybe they are forcing the LSD and i have to slightly cut them (even if my LSD is a KAAZ and not a TRD). Any suggestions? Anyone already experienced a similar problem? Thanks... Keeping the AE86 alive! |
10-09-2008, 11:18 PM
I guess it´s something with the brakes, that doesn´t really go round... Deinstall the everything, including the shaft drives, clean everything and install it with caution. Maybe it´s better then...
Greets raki http://www.sg-rallyesport.de |
10-11-2008, 09:34 AM
Have a read of this.....
http://forums.toyspeed.org.nz/viewtopic.php?t=60138 May or may not have something to do with the noise you hear. Cheers... jondee86 |
| Clutch rattling noise on deceleration | pack | 7 | 1,364 |
11-06-2025 12:43 PM Last Post: pack |
| TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 19 | 24,395 |
04-27-2024 10:04 PM Last Post: banpei |
| AE86 rear axle weight | megabob | 11 | 22,285 |
| Axle width | totta Crolla | 1 | 2,262 |
| Clicking noise from glove box | chrisae86 | 4 | 3,717 |
09-08-2022 11:36 PM Last Post: chrisae86 |
