Clutch Master Cylinder and Clutch Slave Cylinder fitment?
07-01-2009, 07:48 AM
I don't know for a fact, but I would consider it extremely unlikely. The
AE86 slave bolts to a boss on the side of the bell housing, and the fixing
holes would need to be identical... and the bore size... and the alignment
of the hose connector. The master also has to fit the existing mounting
holes (unless you don't mind drilling) and again the bore size and pipe
tappings need to match for a bolt-on installation. Good luck Smile
Cheers... jondee86
Messages In This Thread
[] - jondee86 - 07-01-2009 07:48 AM
  Alu thick core radiator fitment Gtsi-R 5 2,972 01-26-2022 01:28 PM
Last Post: Gtsi-R
  Clutch and brake cylinders MIGGZFSU 4 5,404 10-14-2017 07:52 PM
Last Post: MIGGZFSU
  Brake advice - master cylinder mannix20vt 12 14,224 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 7,322 07-26-2015 12:28 PM
Last Post: bozu
  Dimensions clutch master cylinder bozu 2 6,141 04-16-2015 07:11 AM
Last Post: bozu
