Clutch clunking
05-23-2013, 09:50 AM
Clutch clunking
Hi all,
Every time i engage and disengage the clutch i hear a clunk i've put a new clutch and pressure plate in but i was wondering if it could be the clutch release bearing?
[Image: AEU86 AE86 - Clutch clunking]
05-23-2013, 12:18 PM
Clutch clunking
Did you tighten the bolts as per specification? Sometimes unbalanced bolts can the cause... Also check the clutch master cylinder for leaks...
E12 2.0 D-4D - 2002 - "Mariazinha" - [Image: AEU86 AE86 - Clutch clunking]
G6R - 1998 - "Bebedolas" - [Image: AEU86 AE86 - Clutch clunking]
AE86 - 1987 - "Charutinho" - [Image: AEU86 AE86 - Clutch clunking]
Check out my Youtube Channel with lots of AE86 DIY Guides!
05-23-2013, 03:25 PM
Clutch clunking
I thought i did I'll recheck them. I don't believe the cylinder is leaking but I'll have a look.
05-23-2013, 03:50 PM
Clutch clunking
megabob Wrote:I thought i did I'll recheck them. I don't believe the cylinder is leaking but I'll have a look.
Some more tips:
I dont believe it is the clutch release bearing because usually you hear a whine or whirring sound with the pedal un-pressed when these become worn out, not a clunk, but you can clean the grease there and re-grease it if dry.
While checking, verify the small springs that hold the clutch release fork against the clutch release bearing. Be extremely careful when putting the box back into the engine so that they do not become misaligned.
Place some anti-seize compound between the clutch slave cylinder and the fork to allow for smooth operation.
Check for dirt inside clutch slave cilinder by pulling out the boot and looking inside; if dirty, clean everything and place a bit of new multipurpose grease in there.
05-23-2013, 03:59 PM
Clutch clunking
megabob Wrote:Hi all,
I forgot to ask... does this happen with the car stopped and in neutral?
05-24-2013, 09:12 AM
Clutch clunking
I`ve got the same "problem" in my TA40 (Which I slammed a T50 transmission into), I havent had any real problems yet (Been a year).
Happens specifically when I put it in lower gear with clutch pedal held in, can hear a sound like WHIIITIITITITiiitititittttrrr, almost like a turbo Tongue
If you however feel that it is unsafe, go ahead and replace the release bearing, it`s not an expensive component, keep the old one for spare Smile
Btw, Not to offend or sidewalk you, Homem Bomba, in ANY way,
BUT putting grease into the clutch slave cylinder, as well as WD40/WD 5-56 and so forth ticks of EVERY warning bell and defies every instruction out there, because brake fluid is what keeps the seal, these components dont take well to grease or de-greasers (And in fact speeds up the corrosion process on the cylinder walls/bore)
Just clean with brake fluid and take your time would be my advice (Based on previous experience), in fact, if you absolutely WANT to make sure, a disassembly of the slave cyl to inspect the cylinder bore is recommended.
If corroded, replace both master and slave cyl.
My humble .50`s
1x TA60 82' Sedan 2T 8V
05-24-2013, 01:14 PM
Clutch clunking
Constructive criticism is not an offense in many way, in fact I appreciate you taking the time to explain me why you should not put grease in the slave cylinder Thumbs up!
What about a silicone-based lubricant? I use these whenever I have to lubricate a rubber-based part or boot and no special grease is advised. It says specifically that it is designed not to attack rubbers, unlike WD-40 or MP grease.
However, I do not recommend that you put brake cleaner in rubbers, as it may dry the rubber and make it brittle. In the case of the slave cylinder, the seal may also be damaged.
But the OP has not yet responded to my question... it this happens when the car is moving and in gear (shifting, for example) the problem may not even be related to the clutch at all. In that case, I'd say that the diff backlash needs to be re-tigthtened... its a common problem and ppl think it comes from the clutch, but the clunk is propagated through the propeller shaft and it seems like the problem is clutch related.
I have made a video on how I did the tuning of the differential backlash, it may be of use to anybody needing to adjust it...
[video=youtube]http://www.youtube.com/watch?v=BrE44D0SKKI
Cheers![/video]
05-30-2013, 05:11 PM
Clutch clunking
wow thanks for all the info. sorry for the late reply didn't realize anyone else would respond. Big Grin
05-30-2013, 05:15 PM
Clutch clunking
errr i cant quite remember. I believe that when in neutral its quiet.
05-30-2013, 05:22 PM
Clutch clunking
Homem Bomba Wrote:But the OP has not yet responded to my question... it this happens when the car is moving and in gear (shifting, for example) the problem may not even be related to the clutch at all. In that case, I'd say that the diff backlash needs to be re-tigthtened... its a common problem and ppl think it comes from the clutch, but the clunk is propagated through the propeller shaft and it seems like the problem is clutch related.
Cheers![/youtube]
I'm back Smile , i think you might be right regarding the Diff as its a Cusco 2 way LSD i fitted for Japfest this year but its knackered and defiantly in need of a rebuild.
I've added your vid to my favorites on youtube Cool
  Clutch Master Cylinder and Clutch Slave Cylinder fitment? christsang7 2 5,200 07-01-2009 07:48 AM
Last Post: jondee86
  Clunking noise coming from the rear axle Rasteirinho 3 4,961 10-11-2008 09:34 AM
Last Post: jondee86
  Problem: Soft clutch pedal - no clutch activation dreja 5 7,444 02-09-2006 11:27 PM
Last Post: Denmark
