Coilovers etc...
11-03-2004, 01:19 AM
Coilovers etc...
And Koni's are usually only adjustable for rebound rate, which is of no use for incresing roll resistance.
11-03-2004, 01:44 AM
Coilovers etc...
Ivan141 Wrote:And Koni's are usually only adjustable for rebound rate, which is of no use for incresing roll resistance. Agree. If you set the konis too stif, the spring will be to "weak" to return the shocks to the "neutral" position and your car will be botoming after every bump on the road. If you set shocks too soft, the spring will be too strong and you will have bouncy ride over the bumps. You should go and test it. Drifting - best fun you can have in your car with your pants on! |
11-03-2004, 10:54 AM
Coilovers etc...
I have ridden with a 90 degree turn from the most stiffend position its perfect for an AE86 in my opinion.
The Apex springs are also availbe in lowering i have a measurement table from APEX which puts them on 4kg/mm but your srpings aren't lowerd. The Koni will help against roll if you stiffen it up but seeing Mux his rebound when i pushed his suspension its set to shit Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-03-2004, 11:34 AM
Coilovers etc...
It might not be set very high, but try to understand that they do not become stiffer when pushing them in, so the car will roll even if you set the koni's at their maximum. It only becomes harder for the car to return to normal stance after a corner, and if you take the car through some tight corners in quick succesion with springs that arent very strong you will effectively lower the car down to it's bumpstops. That cant be a good idea now can it.
11-03-2004, 11:41 AM
Coilovers etc...
Quote:If you set the konis too stif, the spring will be to "weak" to return the shocks to the "neutral" position and your car will be botoming after every bump on the road. Zax has a nice idea there..sometimes with really weak springs you can get the car to go lower and lower with each new corner. The end result is the car resting on the bumpstops (which have really nice and high springrates!). This trick is sometimes used in stock class autoX, where only the shocks can be changed out. Its called the "jacking down" effect. But I don't think you can have it without revalving the shocks. Quote:And Koni's are usually only adjustable for rebound rate, which is of no use for increasing roll resistance. I do not agree. Rebound settings are the only settings you should experiment with when you want to increase/decrease roll resistance. Remember, for the car to roll, one side has to go down and the other must go up. Thats where you get the increased roll resistance.. Bump settings should be left alone. Let the bump set for taking in irregularities in the road (function of vehicle speed and more importantly, unsprung weight) and let "bump roll resisance" come from the springs. A wheel to steer the front of the car A pedal to steer the rear |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,047 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,517 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 25,543 |
04-04-2017 02:40 AM Last Post: hachirokkos |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 11,696 |
09-05-2016 12:28 PM Last Post: mad.matt |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 13,365 |
11-19-2013 10:30 PM Last Post: totta Crolla |
