Cooling fan on the hood??
08-10-2011, 03:59 PM
Plenty of race shops have them - driftworks.com for exampel. Alternative if available in your area is ceramic coating.
08-10-2011, 06:30 PM
http://shop.ebay.com/i.html?_nkw=exhaust...rap&_rdc=1
53.6 Tsukuba: http://www.youtube.com/watch?v=Kd-AnG3LYUg
try this one: http://www.youtube.com/watch?v=t1IiUAtoNBk
08-11-2011, 07:25 AM
heshan Wrote:Actually my problem is that the driver and passenger gets quite a bit of heat inside.. Driving during the day with the road being quite warm and the engine heat being leaked into the cabin believe me is painful!!
How do I solve that?
I've lifted my hood to take the heat out of the front of the car over the windshield...
I've lifted the hood at the windshield side about 1.5 inches...
You don't have any problem that you haven't caused yourself!
Quit making things worse. Make sure all air hitting the front goes through the radiator. Don't let engine compartment heat enter the cabin from the high pressure area in front of the windshield.
So what!
08-11-2011, 02:40 PM
To make sure all the air goes through the rad I can put an aluminum sheet between the front of the hood and the rad from the inside correct?
But I apologize for not understanding but what do you mean by
"Don't let engine compartment heat enter the cabin from the high pressure area in front of the windshield."
Are you referring to the area between the hood and the windshield where the wipers and the water draining openings are?
Cheated on my いたずらな女の子 and now I can't get enough of her..
08-11-2011, 04:37 PM
Nice to read this...
I will also consider Ceramic Coating and heatwrapping my car as I also hate the heat coming from the exhaust / engine.
Sometimes you open the door after a bit of a drive and just feel the heat eating my up at the doorside.
But then again I have heat allergies so for me its more severe than any normal human being hahahaha.
-DWG- Drift Wolf Gaming
08-11-2011, 06:30 PM
Have you tried adding an air tube? try to use something like a laundry vent tube to divert air where you want it. just start it at the bumper. It does't look the best, but it works for my cold air intake.
Understeer is when the front end hits the wall.
Oversteer is when your back end hits the wall.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you!
08-11-2011, 07:02 PM
I see that D1 drivers also use tubes for cooling in their suits.
08-11-2011, 09:29 PM
heshan Wrote:Are you referring to the area between the hood and the windshield where the wipers and the water draining openings are?
Yes, it's a high pressure area good for feeding the interior's ventilation system and not so good for letting air out of the hood/bonnet & many manufacturers put a seal/weatherstrip there, while you've opened it up.
I don't know what your alum. sheet is doing, IIRC the AE86 has a seal between the radiator bulkhead and the hood.
So what!
08-12-2011, 07:23 AM
http://honda-tech.com/showthread.php?t=1506827
I did a bit of research lifting the hood from the back a bit before I did. These guys think its a good way to keep air flowing into the engine bay and cooling it..
What I've done is almost like COWL Induction.. Hope it'll work Smile
08-13-2011, 07:32 AM
Splash guard in place under the front end? Even though it's called 'splash' it helps a lot with the air flow around the rad & engine too.
heshan Wrote:bit of research lifting the hood from the back a bit before I did. ...COWL Induction...
Yes, if by 'COWL Induction' you mean helping the engine a little & heating the cabin occupants a lot.
http://www.club4ag.com/faq_and_tech_page...ooling.htm
http://www.club4ag.com/faq_and_tech_page...Part6.html
Thanks Moto-P.
So what!
  Improve 20V Blacktop cooling pack 0 1,365 06-07-2023 01:18 PM
Last Post: pack
  Electric Fan Rasteirinho 3 5,621 08-17-2011 03:27 AM
Last Post: bozu
  Urgent Levin hood question... measurements and weight Okami 8 15,431 03-15-2011 11:36 PM
Last Post: Gtsi-R
  Engine / cooling fluid problem need help asap... Okami 11 15,382 02-15-2011 01:34 PM
Last Post: Okami
  where to place thermoswitch electric fan danielvanderwoude 5 8,266 09-19-2010 07:22 PM
